• PCB and SCH files
    jlbrian706/23/2017 at 02:13 0 comments
    The current version of the ExpressPCB software can be used to open the files.
  • The Code
    jlbrian706/23/2017 at 00:15 0 comments
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    RCT VAR Word
    rcreps VAR Byte
    PDA PIN 7
    RadioSwitch PIN 10
    HIGH RadioSwitch
    PAUSE 3000
    LOW RadioSwitch
    rcreps = 0
    DO
      INPUT PDA
      RCTIME PDA, 1, RCT
      DEBUG ? RCT
      PAUSE 500
      SELECT RCT
        CASE = 0
          rcreps = rcreps + 1
          IF (PDA = 0) THEN
            rcreps = 0
          ELSE
            IF (rcreps = 3) THEN
              LOW RadioSwitch
              rcreps = 0
            ENDIF
          ENDIF
        CASE = 1
          rcreps = rcreps + 1
            LOW RadioSwitch
            rcreps = 0
          ENDIF
        CASE ELSE
          HIGH RadioSwitch
          rcreps = 0
          PAUSE 3000
      ENDSELECT
      DEBUG ? PDA
      DEBUG ? RadioSwitch
    LOOP
    Apparently highlighting isn't available for Basic. Who would have thought.
    This code always worked to switch over to the audio output from the PDA, but would randomly cut the radio out when I wasn't using the PDA.
    I never bothered to fix the problem, or figure out why. I was so happy that I had done something electrical that worked I said 'Fuck it, it's good!'
