MainGchV2.STLIn this version of the adapter, the space between both Joy-Cons has been reduced. Please use this version if you feel that the original one is too big for your hand.simplify3d_stl - 74.40 kB - 08/03/2017 at 15:46 |
MainGchV1.STLSTL file for the adapter.Recommended print settings: -Resolution: 0.3mm -Infill: 25% simplify3d_stl - 79.87 kB - 07/20/2017 at 22:14 |
