Adding custom grinding presets to a Wilfa grinder, presented on a small oled display
To control interface is consisting of four main parts:
The encoder is used to select the different presets. As of now, there are two presets for aeropress and 7 for drip coffee. A curcuit from a mobile charger is providing supply voltage to the arduino from mains.
I had some problems with noice on the encoder signal. I used two 0.1uf caps and 10k resistors to do a hardware debounce, which worked great.
Calibrating rate of ground coffeeI needed to figure out the rate of coffee ground pr second. To do this i simply grind for a specified time interval and measure the mass of ground coffee. Calculating backwards i get a rate of:
Now it is easy to convert the amount of coffee from grams to seconds of grinding.
Further work:
First step was to open the up the grinder and inspect the inner workings. Below is a picture of all the parts:
Grinding mechanism is seen left in the middle. The black wire running around on the part is connected to different safety switches.The PCB controlling the timing and control of the motor is shown below. The motor is controlled using a triac and an 8-bit microcontroller with a potentiometer and a push button as input.
Controller board for the grinderAs of now the plan is to completely replace the controller board with my own components. The task is to make it compact enough to implement it into the machine. Next up is to make a mockup of the control system.
I know this hack is 5 years old! but our Wilfa has broken & this is a great project to give it a new life. Are you able to share your Arduino project code? Many thanks.
Brewing a cup of coffee with a Best Coffee Maker and a grinder is a perfect way to enjoy a flavorful and aromatic cup of coffee every morning. From saving counter space to having an integrated grinder for freshly ground coffee beans, single-cup coffee makers with grinders provide convenience and simplicity for coffee lovers everywhere.
