Another day, another finished print
10/21/2017 at 12:21 • 0 comments -
component after component
10/19/2017 at 19:38 • 0 commentsYesterday nicht my printer has finished the first part oft the case and now it has to print again for quite a long time.. 30 hours or so but I'm printing extra slow to geht the best result. ⚛🕵
The other thing I did was to mill the front panel of my small oled in the upper case-part.
The result is pretty nice !! -
Result of 50 hours oft printing
10/18/2017 at 21:55 • 0 commentsEverything went pretty well and also the first components fit perfectly !!! Ready for more ⚛🤓
Layout and PCB are allready finished !!
10/16/2017 at 19:42 • 0 comments -
Things are getting serious ...
10/16/2017 at 15:13 • 0 commentsCura says the print will take two days... This is definitly the biggest thing I`ve ever printed.. I hope it will work ...
Powering the game
10/16/2017 at 10:34 • 0 commentsTo power up my device I decided to use two lithium-accu-packs and for the savety one of those battery-protectionboards you get for a few bucks on eBay with micro-usb. So my device will be prepared for every party situation even without access to a socket!! :D
The LED-PCB
10/15/2017 at 17:53 • 0 comments
