Our plethora of 3-D printed parts!
10/17/2018 at 02:33 • 0 comments -
Laser Cut Pump Mounts
09/17/2018 at 23:14 • 0 commentsOur Pumps are finally mounted! We went through many iterations of our design before finally getting it right. Some of our prototypes are shown in the second pictures. Our first prototype we cut out of cardboard, then we cut the second prototype out of wood and our final design is cut out of 9mm thick acrylic plastic.
Grow Tray Complete!!
09/08/2018 at 00:53 • 0 comments -
Merris Using Power Tools!!
09/07/2018 at 20:26 • 0 commentsWe made some wooden stands for the grow tray which will hold the plants and the conditioning tank which will hold the sensors that measure pH, electrical conductivity, dissolved oxygen, and temperature. Featured in this photo is Merris Beadle operating a circular saw to make the cuts!
3D Printing a Gear Train
08/21/2018 at 19:50 • 0 commentsWe printed a gear reduction unit to connect the peristaltic pump with the worm gear motor. Through testing we realized that our tiny 100 rpm motor did not have enough torque to turn our enlarged peristaltic pump and this is our solution!
3D Printed Peristaltic Pump
08/16/2018 at 22:46 • 0 commentsThis week we have been working to print and test a peristaltic pump design. First, we printed a miniature version which has a 53mm diameter to test the gears. The second version that we printed is about a 93mm diameter and we tested it with a screw driver and some tubing to see if it moves water. Peep the video below to see the result!
Prototyping in cardboard
08/08/2018 at 23:51 • 0 commentsLast week we succeeded in printing a working Archimedes screw pump. This week we have begun to create a prototype design which will mount the Archimedes screw pump and worm gear motor to the conditioning tank. We choose to create our first prototypes in cardboard because it was the most time efficient. Later we will sketch these mounts up in a CAD program and laser cut them.
