The Boards Have Arrived!
A project log for One Tube Nixie Clock
It is time to take my nixie hardware testbed from the breadboard stage to something that doesn't have wires sprouting everywhere.
paul-andrewsPaul Andrews 01/09/2018 at 01:432 Comments
The boards have arrived! Unfortunately it is going to be a couple of weeks before I get to do anything with them. While I was waiting, I was honing the software, which is pretty much ready to go.
Here are some screen-shots from the web GUI. The Clock screen lets you configure all of the actual time display features.
The Time Server URL is used to synchronize the time with NTP and adjust for timezone and DST - I blanked it out in this image:
The LEDs screen allows you to control the backlight and reflects the current state of the backlight in real time using web sockets push from the clock.
The Extra screen allows you to change the purpose of the hardware:
There are so many options that it comes with five presets that you can just jump between. If you make changes to a preset, they are saved automatically, and you can rename the presets.
Finally, there is an info screen:
Petr wrote 04/26/2019 at 09:48 point
Hello.
How can i use ur webserver via arduino ide?
aperfectecho wrote 02/04/2018 at 15:39 point
Very interested in this project! I have a Nixue IN-18 Blue Dream, and also a tube tester/healer. I like this idea a lot-any chance of an Android app too? Otherwise, I'd use it on an iPad
