NOP.PLD.txtDual-purpose 22V101. Forces NOP codes on the data bus during video access cycles. 2. Read the keyboard data. 22V10 text/plain - 1.68 kB - 08/25/2023 at 20:31 |
DECODE.PLD.txtThe memory map decoder and 3-bit tri-state counter for character row generation.22V10 text/plain - 2.48 kB - 08/25/2023 at 02:16 |
SHIFT.PLD.txtThe shift register for video generation.Half latches the character data D0-7 to drive the character ROM address lines later. Half latches the character data D0-7 into a shift register to drive the video signal. ATV750. plain - 3.27 kB - 08/25/2023 at 02:17 |
HSYNC.PLD.txtThe horizontal sync generator for video generation.ATV750 Contains the SLOW mode timing generator. The divisor is 208, because 3.25 MHz/208 = 15625 Hz line frequency. For square-pixel-40-column-PAL 14.75/2=7.375, the divisor should be 236. For square-pixel-40-column-NTSC 12+3/11/2=3.068 MHz and 15750 line rate, the divisor should be 195. plain - 3.24 kB - 08/25/2023 at 02:17 |
KEYFIX.PLD.txtThe Keyboard remapper. Not needed if you have a ZX81-compatible keyboard matrix.ATV750 text/plain - 2.90 kB - 08/25/2023 at 02:16 |
K8082.pdfMy best guess at the wiring.Adobe Portable Document Format - 45.74 kB - 01/12/2018 at 03:05 |
ZX81_in_SPLD_chips.zipHTML documentation. Start page is ZX81_SPLD.htmx-zip-compressed - 113.32 kB - 01/10/2018 at 23:36 |
