cnc_masin_v2_export.stpexported assembly file with all components. Date 18 Jan 2016 snapshot of the plans.stp - 5.08 MB - 01/18/2016 at 10:00 |
6mm_nestings_kokku.dxfThe main machine parts, kerf compensated, 6mm plexi (or any other 6mm thick material, initial design was for 6mm aluminium).- 241.39 kB - 01/28/2016 at 10:46 |
2mm_nestings_kokku.dxfKerf compensated, cable chain parts (2mm plexi but any 2mm thick material should work, also published in CrabCAD site without kerf compensation)AutoCAD DXF - 41.36 kB - 01/18/2016 at 09:38 |
x-plate.dxfa piece of the machine, provided in a separate file as well just on case. not kerf compensated.AutoCAD DXF - 23.41 kB - 01/18/2016 at 09:36 |
y-side-plate.dxfa piece of the machine, provided in a separate file as well just on case. not kerf compensated.AutoCAD DXF - 22.04 kB - 01/18/2016 at 09:36 |
y-plate.dxfa piece of the machine, provided in a separate file as well just on case. not kerf compensated.AutoCAD DXF - 18.27 kB - 01/18/2016 at 09:36 |
y-back-plate.dxfa piece of the machine, provided in a separate file as well just on case. not kerf compensated.AutoCAD DXF - 18.75 kB - 01/18/2016 at 09:36 |
x-under-rib-horisontal.dxfa piece of the machine, provided in a separate file as well just on case. not kerf compensated.AutoCAD DXF - 19.01 kB - 01/18/2016 at 09:36 |
x-under-rib-vert.dxfa piece of the machine, provided in a separate file as well just on case. not kerf compensated.AutoCAD DXF - 17.34 kB - 01/18/2016 at 09:36 |
x-side-plate.dxfa piece of the machine, provided in a separate file as well just on case. not kerf compensated.AutoCAD DXF - 21.76 kB - 01/18/2016 at 09:36 |
x-front-plate.dxfa piece of the machine, provided in a separate file as well just on case. not kerf compensated.AutoCAD DXF - 26.11 kB - 01/18/2016 at 09:36 |
x-alus-1.dxfa piece of the machine, provided in a separate file as well just on case. not kerf compensated.AutoCAD DXF - 20.28 kB - 01/18/2016 at 09:36 |
z-top-and-bottom-plate.dxfa piece of the machine, provided in a separate file as well just on case. not kerf compensated.AutoCAD DXF - 20.02 kB - 01/18/2016 at 09:36 |
z-plate.dxfa piece of the machine, provided in a separate file as well just on case. not kerf compensated.AutoCAD DXF - 21.41 kB - 01/18/2016 at 09:36 |
x-alus-2.dxfa piece of the machine, provided in a separate file as well just on case. not kerf compensated.AutoCAD DXF - 20.28 kB - 01/18/2016 at 09:36 |
nema17_extraplate.dxfa piece of the machine, provided in a separate file as well just on case. not kerf compensated.AutoCAD DXF - 18.61 kB - 01/18/2016 at 09:36 |
Jupid.odsA list of plexi parts and a note on how many of each do you needspreadsheet - 11.53 kB - 01/18/2016 at 09:28 |
Mechanical system.odsA spreadsheet - it's work in progress so not some kind of finalized list, but if anyone wants to take a look then its here.spreadsheet - 21.66 kB - 01/18/2016 at 09:27 |
