• 1
    Step 1
    Saw off 2 48 mm pieces of dowel rod
  • 2
    Step 2
    drill a hole 10 mm deep into one of the ends
  • 3
    Step 3
    Drill a hole through the side off the rod 7 mm from the end into which you have drilled the other hole
