PCBs submitted to OSHPark
A project log for Intel Edison: USB Storage Sled
Prototype design of a USB Storage Sled for use with the Intel Edison IoT module. Implements SATA & PATA.
zittwarezittware 03/19/2015 at 06:250 Comments
Quick note to let you know that two different boards were submitted to OSH park. The first was the USB Storage Sled 4layer board. The second was a Dummy Intel Edison board (2 layers). The latter supplies 3.3V and 1.8Vs to the USB Storage Sled along with #RESET ... The idea is that cheap board would be used in place the Intel Edison Module; Allowing me to test the board using a standard pc/hub; rather than risking the Edison with wiring errors.
The Sled was submitted to OSHPark on March 13th. The Dummy board was submitted yesterday (3/17).
