V1.0 PCBs arrived
08/08/2018 at 19:39 • 0 commentsThe v1.0 PCBs are here!
You can purchase the v1.0 kit on the tindie page. -
Tindie kit
07/16/2018 at 11:38 • 0 commentsThere is now a tindie kit available for purchase of the v0.4 prototype.
At the moment I only have the leftover parts from the prototypes, but I ordered more parts and new boards so I can have more kits in stock.https://www.tindie.com/products/untemed/10-mhz-function-generator-diy-kit/
User manual
07/12/2018 at 13:18 • 0 commentsI've wrote a user manual on how to operate the device once in its original form Link.
Project files released
07/07/2018 at 18:50 • 0 commentsI've finished doing various bug fixes, so now the files have been published.
The next step is to write s user manual. -
Bugs
07/02/2018 at 15:15 • 0 commentsI've found a few minor bugs with the firmware that need to be fixed.
Once that is done I'll do a minor PCB revision with only layout changes.
When I'll have everything completed and fixed I'll publish the project files. -
Firmware first version completed
06/20/2018 at 01:29 • 0 commentsI've completed the first version of the firmware with the basic functions and frequency sweep.
Unfortunatly only about 140b of program memory is left so there isn't much space to add more features without upgrading
the mcu. -
v0.4 completed
05/19/2018 at 21:42 • 0 commentsI got the v0.4 pcb-s and soldered the parts and it works!
Everything now works as it should, all the voltages are matching as they should (previous version had some offsets).
Now the only thing left is to finish the firmware (and find two 100 ohm resistor somewhere).
Also the knobs are a bit large, so I'm looking for alternatives on ebay to replace them so the scale on the pcb is more visible. -
v0.3 completed
05/10/2018 at 00:27 • 0 commentsI finished with the v0.3 and it works with a few minor bodges.
Now I'm about to order the v0.4 which should hopefully be the final version with the final modifications. -
v0.3 PCB ordered
04/11/2018 at 13:00 • 0 commentsI finished routing the v0.3 PCB and ordered it.
v0.3 Schematic
04/08/2018 at 18:26 • 0 commentsI managed to add square waves to the output waveform types with a 74HC4053 without affecting the price too much.
Now I have to make a new PCB and test it out.
Link: Schematic
