Graphics Interchange Format - 8.51 MB - 05/16/2018 at 21:34 |
swissmak in repetier host1.pngAxes are incorrectly labeled here, but Repetier host runs the SwissMak just fine.Portable Network Graphics (PNG) - 143.81 kB - 05/05/2018 at 20:16 |
x_t - 396.82 kB - 05/04/2018 at 00:19 |
Standard Tesselated Geometry - 1.16 MB - 05/03/2018 at 01:42 |
JPEG Image - 403.95 kB - 04/05/2018 at 03:19 |
JPEG Image - 557.54 kB - 04/05/2018 at 03:19 |
JPEG Image - 394.77 kB - 04/05/2018 at 03:19 |
JPEG Image - 473.03 kB - 04/05/2018 at 03:19 |
JPEG Image - 348.49 kB - 04/05/2018 at 03:19 |
castiron4axismillinggif.gifHigher depth of cut on a cast iron bar to evaluate rigidity.Graphics Interchange Format - 9.81 MB - 03/19/2018 at 22:42 |
milling spindle cross section prototype2.jpgA simplified side view of the prototype spindle and drawbar mechanism.JPEG Image - 65.29 kB - 03/06/2018 at 02:48 |
linearrepeatabilitygif.gifThe linear axes can move smoothly within 0.001"Graphics Interchange Format - 9.92 MB - 03/01/2018 at 03:06 |
swively.gifThe B axis in motion.Graphics Interchange Format - 13.11 MB - 03/01/2018 at 02:41 |
facinggif.gif4 inch 6061 tube.Graphics Interchange Format - 9.88 MB - 03/01/2018 at 02:41 |
JPEG Image - 4.28 MB - 02/26/2018 at 06:43 |
JPEG Image - 4.41 MB - 02/26/2018 at 06:43 |
JPEG Image - 4.22 MB - 02/26/2018 at 06:43 |
JPEG Image - 4.16 MB - 02/26/2018 at 06:43 |
JPEG Image - 4.38 MB - 02/26/2018 at 06:43 |
JPEG Image - 4.19 MB - 02/26/2018 at 06:42 |
JPEG Image - 5.09 MB - 02/26/2018 at 06:40 |
JPEG Image - 5.16 MB - 02/26/2018 at 06:40 |
JPEG Image - 4.97 MB - 02/26/2018 at 06:40 |
JPEG Image - 4.59 MB - 02/26/2018 at 06:40 |
JPEG Image - 4.66 MB - 02/26/2018 at 06:40 |
JPEG Image - 5.19 MB - 02/26/2018 at 06:39 |
JPEG Image - 4.63 MB - 02/26/2018 at 06:38 |
JPEG Image - 4.19 MB - 02/26/2018 at 06:38 |
JPEG Image - 5.00 MB - 02/26/2018 at 06:38 |
JPEG Image - 5.25 MB - 02/26/2018 at 06:37 |
JPEG Image - 5.56 MB - 02/26/2018 at 06:37 |
JPEG Image - 5.22 MB - 02/26/2018 at 06:37 |
JPEG Image - 5.41 MB - 02/26/2018 at 06:37 |
JPEG Image - 4.00 MB - 02/26/2018 at 06:36 |
JPEG Image - 5.25 MB - 02/26/2018 at 06:34 |
JPEG Image - 4.78 MB - 02/26/2018 at 06:34 |
JPEG Image - 4.47 MB - 02/26/2018 at 06:34 |
JPEG Image - 4.97 MB - 02/26/2018 at 06:34 |
JPEG Image - 4.69 MB - 02/26/2018 at 06:34 |
JPEG Image - 4.94 MB - 02/26/2018 at 06:34 |
JPEG Image - 4.16 MB - 02/26/2018 at 06:33 |
JPEG Image - 4.59 MB - 02/26/2018 at 06:33 |
JPEG Image - 4.03 MB - 02/26/2018 at 06:33 |
JPEG Image - 4.66 MB - 02/26/2018 at 06:33 |
JPEG Image - 4.56 MB - 02/26/2018 at 06:33 |
JPEG Image - 4.63 MB - 02/26/2018 at 06:33 |
JPEG Image - 4.69 MB - 02/26/2018 at 06:33 |
JPEG Image - 4.75 MB - 02/26/2018 at 06:33 |
JPEG Image - 4.38 MB - 02/26/2018 at 06:32 |
JPEG Image - 4.97 MB - 02/26/2018 at 06:32 |
JPEG Image - 4.91 MB - 02/26/2018 at 06:32 |
JPEG Image - 4.66 MB - 02/26/2018 at 06:32 |
JPEG Image - 5.22 MB - 02/26/2018 at 06:32 |
JPEG Image - 4.06 MB - 02/26/2018 at 06:32 |
JPEG Image - 4.50 MB - 02/26/2018 at 06:32 |
odrivegif.gifCould the product placement be more blatant?Graphics Interchange Format - 8.21 MB - 02/26/2018 at 06:30 |
trihotendfinishedgif.gifSwissMak makes clean, smooth, flat surfaces when millingGraphics Interchange Format - 7.05 MB - 02/26/2018 at 06:03 |
movementgif.gifLots of axes. Still easy to programGraphics Interchange Format - 17.76 MB - 02/23/2018 at 08:28 |
side milling.gif3kW motor, 6,000 rpmGraphics Interchange Format - 11.17 MB - 02/23/2018 at 08:28 |
manualtoolchangegif.gifTakes about 10 seconds. There will be an ATC on the production versionGraphics Interchange Format - 8.01 MB - 02/23/2018 at 08:28 |
turretindexinggif.gifGoes both directions, self locking design. The bevel gear in the middle is for live tooling blocksGraphics Interchange Format - 6.25 MB - 02/23/2018 at 08:27 |
overviewgif.gifJust under 2 meters end to end, weights as much as a few adult humans.Graphics Interchange Format - 19.80 MB - 02/23/2018 at 08:27 |
