Vertical Test Stand and Rocket Construction
A project log for High Power Experimental Rocket Platform
Experimental high power rocket with active stabilization, live telemetry, autonomous GPS guided recovery and HD video
j-m-hopkinsJ. M. Hopkins 07/03/2015 at 22:340 Comments
The new test stand shields nearly 200 degrees with thick 2x4 in the case of another CATO while providing vertical thrust transfer to a scale beneath the stand to allow for thrust curve measurements.
Constructon of the HPR has started. 3" tubing with plywood rings and fins should allow this rocket significant motor choices with high thrust.
