Nose Cone
A project log for High Power Experimental Rocket Platform
Experimental high power rocket with active stabilization, live telemetry, autonomous GPS guided recovery and HD video
j-m-hopkinsJ. M. Hopkins 07/04/2015 at 22:120 Comments
Here is a good photo that shows the fin configuration and general feel of the rocket.
The nose cone is rolled thick construction card stock reinforced with wood filler. The inside of the cone will be foam filled once nose weight is determined necessary.
