1Step 1
I bought the enclosure at my local electrics store and hot glued everything in place.
The cutout for the temperature/humidity sensor was made with a box cutter.
The Arduino source code can be downloaded here: Project Oro
Hi Richard,
I find very interesting your project as I want to control solar thermal installations via SMS. I can't find the Regexp.h library. Could you tell me where to get it from?
Thanks
I've got a error compiling the project:
Oro.ino: In function ‘String GetTempData()’:Oro.ino:411:29: error: call of overloaded ‘String(float&)’ is ambiguous
Oro.ino:411:56: error: call of overloaded ‘String(float&)’ is ambiguous
The line is:
return TXT_Humid+String(h)+"%\r\n"+TXT_Temp+String(t);
Thank you for share the project.
Hi langtupt,...
what's the problem?
Hi Bro,
Can you help using rain sensor with sim900a and arduino?
