The previous "SDuino on wrist" was a bit hard to read its digit and Nyancat, so this time,,
I rotate 90 deg to read well !
The function and circuit is exactly the same (Lipo battery and charging circuit), but
I inserted a string of plastic sheet (actually it is SD card holder cut by scissors...)
and it is working as "very low-efficiency light-wave waveguide". When it turns green, battery inside is full, and will turn red during charging....
That's amazing! What all does it do currently?
that looks awesome :)
Thank you!!!!
