Aquiring Parts
09/20/2015 at 23:45 • 0 commentsHere is my latest video giving an update on my project (for the Sept. 21 deadline).
Note: Since I have already built my first prototype (and it was shown to be operational in the first video), I decided to simply give an overview of where the 2nd prototype is going.
Precision Needle Valve for Deuterium Control
09/07/2015 at 03:58 • 0 commentsRecently purchased an Edwards needle valve for controlling the deuterium off of ebay for 75 bucks. I also purchased some tungsten rods off of amazon to contruct the inner and outer grids: http://www.amazon.com/b/ref=dp_bc_5?ie=UTF8&node=11260366011
Vacuum Chamber
08/27/2015 at 04:00 • 0 commentsAn aluminum high vacuum chamber was just purchased for our project off of ebay. It was only about $100. It has an ID of about 6 inches. It should be very easy to machine and modify. If this chamber does not hold a sufficient vacuum, we plan on adding a glass bell jar over it to hopefully fix the problem. -
Basic Plan for the Vacuum Chamber
08/17/2015 at 01:15 • 0 commentsSource: http://www.instructables.com/id/Build-A-Fusion-Reactor/?ALLSTEPS
Currently, all that I have is a mechanical pump, and a chamber.
As a side note, I also have heavy water, however I have not begun to setup a system for electrolysis.
Reading up on IEC Fusion Theory
08/16/2015 at 23:07 • 0 commentsHere are just a few of the sources that I will begin to dig through:
http://ssl.mit.edu/publications/theses/PhD-2007-McGuireThomas.pdf
http://ssl.mit.edu/publications/theses/PhD-2007-DietrichCarl.pdf
https://smartech.gatech.edu/bitstream/handle/1853/21828/seltzman_andrew_h_200805_phys.pdf
http://www.dallastown.net/cms/lib6/pa01000011/centricity/domain/99/kovalchick.pdf
High Voltage Source
08/16/2015 at 22:54 • 0 commentsThe neutron counter that I purchased requires 1500 V to operate. I believe that the following source, coupled with a voltage divider, may be able to do the trick:
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_2100136_-1
Neutron Detector
08/16/2015 at 22:34 • 0 commentsPurchased this Corona neutron detection tube for future detection of fusion:
Demonstration Fusor
08/14/2015 at 01:48 • 0 commentsThe demonstration fusor was to just get my feet wet.
