Kortex-S Processor
Bit serialized ARM Cortex Processor
Bit serial implementation of ARM CPU. Very slow, very small. Goal is that it can fit into VERY small FPGA.
What if
we could schrink the Cortex-M0 core to fit into the smallest target silicon available?
We could then take standard GCC and compile code that runs in CHIP made by YOU!
Smaller than grain of sand, priced at 1 USD.
Nah, this is not possible !?
GOAL
  1. Optimized bit-serial implementation of Cortex-M0 ISA
  2. Resource usage
    1. LUT4 <= 500
    2. Flip-Flop <= 500
    3. block RAM primitives < 4 (not counting program and data memories)
    4. clocks per instruction < 128
The resource usage should be less than 50% of Lattice HX1K or XO2-1200 FPGA
  • I found the sources...
    Antti Lukats08/22/2015 at 20:12 0 comments
    searching on HDD sometimes completes in finite time with results.. so the sources are found. The processor is not yet usable but can still be used as starting point.
    pushed to github...
View project log
Yann Guidon / YGDES wrote 08/23/2015 at 17:23 point
Why not call it KortekS ? Or Core-Tech-S ? :-)
Antti Lukats wrote 08/23/2015 at 17:38 point
Calculated risk. Sensing the borders when C&D Letter comes. Should that happen, then fun begins..
Yann Guidon / YGDES wrote 08/23/2015 at 17:41 point
but a pun is funnier than a lawyer ;-)
