1Step 1
Go to github and check out these four repositories:
2Step 2
The "SPI driver" and "NRF24L01 driver" should be checked out into your Arduino IDE's library/ directory. The Arduino-Makefile and Soot-Sprites Network repositories can be cloned anywhere you prefer.
3Step 3
In the Soot-Sprites Network's hardware/avr/sensor-node/ directory, there should be a Makefile. Adjust the make variable ARDMK_DIR to reflect the path that you cloned the Arduino-Makefile into.You should be able to build a version of soot-sprite that supports the devduino v2.
