Some Global Settings & IO Standard
10/07/2015 at 23:06 • 0 commentsGlobals FAMILY "Cyclone IV E" DEVICE EP4CE22F17C6 DEVICE_FILTER_PACKAGE FBGA DEVICE_FILTER_PIN_COUNT 256 Other IO_STANDARD "3.3-V LVTTL" *This should be the setting for all pins -
GPIO0
10/07/2015 at 22:28 • 0 commentsHere the pin name is prefixed with the letter 'a', but this can be changed to anything unique.
GPIO0 Pin Name PIN_A8 a_IN[0] PIN_D3 a[0] PIN_B8 a_IN[1] PIN_C3 a[1] PIN_A2 a[2] PIN_A3 a[3] PIN_B3 a[4] PIN_B4 a[5] PIN_A4 a[6] PIN_B5 a[7] PIN_A5 a[8] PIN_D5 a[9] PIN_B6 a[10] PIN_A6 a[11] PIN_B7 a[12] PIN_D6 a[13] PIN_A7 a[14] PIN_C6 a[15] PIN_C8 a[16] PIN_E6 a[17] PIN_E7 a[18] PIN_D8 a[19] PIN_E8 a[20] PIN_F8 a[21] PIN_F9 a[22] PIN_E9 a[23] PIN_C9 a[24] PIN_D9 a[25] PIN_E11 a[26] PIN_E10 a[27] PIN_C11 a[28] PIN_B11 a[29] PIN_A12 a[30] PIN_D11 a[31] PIN_D12 a[32] PIN_B12 a[33] -
GPIO1
10/07/2015 at 22:21 • 0 commentsHere the pin name is prefixed with the letter 'b', but this can be changed to anything unique.
GPIO1 Pin Name PIN_T9 b_IN[0] PIN_F13 b[0] PIN_R9 b_IN[1] PIN_T15 b[1] PIN_T14 b[2] PIN_T13 b[3] PIN_R13 b[4] PIN_T12 b[5] PIN_R12 b[6] PIN_T11 b[7] PIN_T10 b[8] PIN_R11 b[9] PIN_P11 b[10] PIN_R10 b[11] PIN_N12 b[12] PIN_P9 b[13] PIN_N9 b[14] PIN_N11 b[15] PIN_L16 b[16] PIN_K16 b[17] PIN_R16 b[18] PIN_L15 b[19] PIN_P15 b[20] PIN_P16 b[21] PIN_R14 b[22] PIN_N16 b[23] PIN_N15 b[24] PIN_P14 b[25] PIN_L14 b[26] PIN_N14 b[27] PIN_M10 b[28] PIN_L13 b[29] PIN_J16 b[30] PIN_K15 b[31] PIN_J13 b[32] PIN_J14 b[33] -
2x13 GPIO Header
10/07/2015 at 22:07 • 0 comments(Better map, this is wierd.)
2x13 GPIO Header Pin Name PIN_A14 GPIO_2[0] PIN_B16 GPIO_2[1] PIN_C14 GPIO_2[2] PIN_C16 GPIO_2[3] PIN_C15 GPIO_2[4] PIN_D16 GPIO_2[5] PIN_D15 GPIO_2[6] PIN_D14 GPIO_2[7] PIN_F15 GPIO_2[8] PIN_F16 GPIO_2[9] PIN_F14 GPIO_2[10] PIN_G16 GPIO_2[11] PIN_G15 GPIO_2[12] PIN_E15 GPIO_2_IN[0] PIN_E16 GPIO_2_IN[1] PIN_M16 GPIO_2_IN[2] -
SDRAM
10/07/2015 at 21:51 • 0 commentsHere the outline for the SDRAM is barely visible, the chip is on the underside of the board.
SDRAM Pin Name PIN_M7 DRAM_BA[0] PIN_M6 DRAM_BA[1] PIN_R6 DRAM_DQM[0] PIN_T5 DRAM_DQM[1] PIN_L2 DRAM_RAS_N PIN_L1 DRAM_CAS_N PIN_L7 DRAM_CKE PIN_R4 DRAM_CLK PIN_C2 DRAM_WE_N PIN_P6 DRAM_CS_N PIN_G2 DRAM_DQ[0] PIN_G1 DRAM_DQ[1] PIN_L8 DRAM_DQ[2] PIN_K5 DRAM_DQ[3] PIN_K2 DRAM_DQ[4] PIN_J2 DRAM_DQ[5] PIN_J1 DRAM_DQ[6] PIN_R7 DRAM_DQ[7] PIN_T4 DRAM_DQ[8] PIN_T2 DRAM_DQ[9] PIN_T3 DRAM_DQ[10] PIN_R3 DRAM_DQ[11] PIN_R5 DRAM_DQ[12] PIN_P3 DRAM_DQ[13] PIN_N3 DRAM_DQ[14] PIN_K1 DRAM_DQ[15] PIN_P2 DRAM_ADDR[0] PIN_N5 DRAM_ADDR[1] PIN_N6 DRAM_ADDR[2] PIN_M8 DRAM_ADDR[3] PIN_P8 DRAM_ADDR[4] PIN_T7 DRAM_ADDR[5] PIN_N8 DRAM_ADDR[6] PIN_T6 DRAM_ADDR[7] PIN_R1 DRAM_ADDR[8] PIN_P1 DRAM_ADDR[9] PIN_N2 DRAM_ADDR[10] PIN_N1 DRAM_ADDR[11] PIN_L4 DRAM_ADDR[12] -
EPCS
10/07/2015 at 21:37 • 0 commentsEPCS Pin Name PIN_H2 EPCS_DATA0 PIN_H1 EPCS_DCLK PIN_D2 EPCS_NCSO PIN_C1 EPCS_ASDO -
Accelerometer & EEPROM
10/07/2015 at 21:33 • 0 comments(Why are these tied together? Implications?)
Accelerometer & EEPROM Pin Name PIN_F2 I2C_SCLK PIN_F1 I2C_SDAT PIN_G5 G_SENSOR_CS_N PIN_M2 G_SENSOR_INT -
ADC
10/07/2015 at 21:26 • 0 commentsADC Pin Name PIN_A10 ADC_CS_N PIN_B10 ADC_SADDR PIN_B14 ADC_SCLK PIN_A9 ADC_SDAT -
Switch
10/07/2015 at 21:24 • 0 commentsSwitch (DIP Switch) Pin Name PIN_M1 SW[0] PIN_T8 SW[1] PIN_B9 SW[2] PIN_M15 SW[3] -
Key's
10/07/2015 at 21:21 • 0 commentsKey (Push Button) Pin Name PIN_J15 KEY[0] PIN_E1 KEY[1]
