IMG_1071.JPGFront Crossmember cut to fit Smart Car controllerJPEG Image - 1.33 MB - 12/30/2015 at 21:52 |
IMG_0411.JPGStock transmission bell housingJPEG Image - 2.45 MB - 12/30/2015 at 21:52 |
IMG_0526.jpgCAD (cardboard aided design) (I'll learn solid works soon)JPEG Image - 1.88 MB - 12/30/2015 at 21:52 |
IMG_0562.JPGCutting the transmission input shaft for prototyping purposes. I will make a custom shaft eventually.JPEG Image - 1.86 MB - 12/30/2015 at 21:51 |
IMG_0889.jpgSonett interiorJPEG Image - 1.37 MB - 12/30/2015 at 21:51 |
IMG_0939.JPGThinking about a tilt-up bonnet for my SonettJPEG Image - 1.36 MB - 12/30/2015 at 21:51 |
IMG_1040.JPGCutting out rustJPEG Image - 1.21 MB - 12/30/2015 at 21:51 |
IMG_0551.JPGprototyping engine/transmission shaft adaption.JPEG Image - 2.12 MB - 12/30/2015 at 21:50 |
IMG_1072.jpgMiddle engine-bay crossmember cut to fit mystery screw in motor. I can't get that screw out, but I'm guessing it's a drain plug for the coolant.JPEG Image - 1.75 MB - 12/30/2015 at 21:50 |
IMG_0891.JPGStock instrument cluster. Since the speedometer and odometer are mechanical off of the transmission I can use the originals! I'll get new gauges for the others.JPEG Image - 1.41 MB - 12/30/2015 at 21:49 |
IMG_1068.JPGEngine/transmission hanging in place. Bolted in my the transmission pin and hooked up to the T drivers. Basically ready to go!JPEG Image - 2.28 MB - 12/30/2015 at 21:49 |
IMG_1060.JPGBody-work. The drivers side brake line goes through the engine bay wall. It was full of holes.JPEG Image - 1.13 MB - 12/30/2015 at 21:49 |
IMG_0832.jpg17 spline female motor shaft.JPEG Image - 2.03 MB - 12/30/2015 at 21:49 |
IMG_1047.JPG"This is a two-bay job." or... What we do when we don't have to share for the weekend.JPEG Image - 1.99 MB - 12/30/2015 at 21:48 |
IMG_0937.JPGMy sweet winter set up. W/ heatJPEG Image - 6.38 MB - 12/30/2015 at 20:23 |
IMG_0682.JPGSo, the bearings are shot...JPEG Image - 2.26 MB - 12/30/2015 at 20:23 |
IMG_0676.jpgBits of bearing guides on my magnetic transmission drain plugJPEG Image - 2.10 MB - 12/30/2015 at 20:23 |
IMG_0163.JPGDamn, I think this car is so hot.JPEG Image - 1.91 MB - 12/30/2015 at 20:23 |
IMG_0837.jpgSketch of the motor shaft spline pattern.JPEG Image - 2.55 MB - 12/30/2015 at 20:23 |
IMG_0523.JPGI need another transmission. This one is bad.JPEG Image - 2.25 MB - 12/30/2015 at 20:23 |
IMG_0762.jpgTransmission input shaft in the motor output shaft. The tranny shaft doesn't have splines, this was just to mockup the adapter plate.JPEG Image - 1.44 MB - 12/30/2015 at 20:21 |
IMG_0756.jpgMotor and transmission. Together at last!JPEG Image - 2.50 MB - 12/30/2015 at 20:20 |
