Adapting the Motor
A project log for Electric Sonett: Old Car/New Tech
This project focuses on ecological sustainability and social responsibility through reuse. Increasing lifecycle efficiency, decreasing cost.
adam-curtisAdam Curtis 11/19/2015 at 15:470 Comments
For the past couple of days I've been working to adapt the motor to the transmission. This is a fun process and it's going really smoothly. I'm designing the adapter plate with cardboard for now but hope to put all of the measurements in solidworks and CNC a plastic prototype to see if everything checks out before going to aluminum.
Adapting the motor shaft to the transmission is also going well, but I'm not %100 sure that I'm doing it the best way. Yesterday I cut the splined center piece out of the original clutch plate. This has the correct splines for the transmission of course. I turned it down to the same diameter as the motor shaft keeping it concentric around the splines. I'm not sure what the best course of action for attaching these two shafts is though. Any suggestions?
