RAR Archive - 5.16 MB - 05/17/2016 at 14:59 |
Adobe Portable Document Format - 587.25 kB - 03/17/2016 at 21:07 |
x-zip-compressed - 3.02 MB - 03/10/2016 at 03:46 |
Adobe Portable Document Format - 2.44 MB - 03/08/2016 at 21:38 |
Microsoft Html Help File - 831.28 kB - 03/08/2016 at 20:43 |
lwiplib.c Line 192
Edit 3-10-2016:
I think I fixed the problem. From the instructions on the TI Page (http://processors.wiki.ti.com/index.php/LAUNCHXL2_RM57L:_lwIP_Demo)
Where it says to change the function on balls T4 and U7. HALCoGen show this.
The problem is that there is not MII_RX_AVCLK4 or MII_TX_AVCLK4 on these balls, and selecting MII_RXCLK and MII_TX_CLK show a conflict.
So, switching MII_RXCLK from T4 to K19, and MII_TX_CLK from U7 to D19, and going back to the pin muxing tab, and setting the pins there removed the conflict.
I got the following output form ccsI have to wait until the mac address is added to the network to know if this actually fixed anything.I couldn't make any headway after the MAC address was added to the network. The board would hang while trying to resolve the ip address. I rolled back to last nights code, and it worked the first time.
However after restarting the board I got the same results as last night. This works intermittently at best.
I may try this with a static IP, and see if I get better results, otherwise I'm going to go with the TM4C1294XL
void main(){
adcData_t adc_data; //ADC Data Structure
adcData_t *adc_data_ptr = &adc_data; //ADC Data Pointer
unsigned int NumberOfChars;
uint16 trimmer_val;
uint16 hyd_pos_val;
uint16 air_pos_val;
uint32 adc_id;
adcInit();
while(1){
adcStartConversion(adcREGx, adcGroup1); //Start ADC conversion
while(!adcIsConversionComplete(adcREGx, adcGroup1)); //Wait for ADC conversion
int i;
for (i=3; i > 0; i--){
adcGetData(adcREGx, adcGroup1, adc_data_ptr); //Store conversion into ADC pointer
adc_id = adc_data_ptr->id;
switch (adc_id){
case 6:
trimmer_val = adc_data_ptr->value;
NumberOfChars = ltoa(trimmer_val,(char *)command);
sciDisplayText(sciREGx, (uint8_t*)"Trimmer: 0x", sizeof("Trimmer: 0x"));
sciSend(sciREGx, NumberOfChars, command);
sciDisplayText(sciREGx, txtCRLF, sizeof(txtCRLF));
break;
case 10:
hyd_pos_val = adc_data_ptr->value;
NumberOfChars = ltoa(hyd_pos_val,(char *)command);
sciDisplayText(sciREGx, (uint8_t*)"HYD_POS: 0x", sizeof("HYD_POS: 0x"));
break;
case 17:
air_pos_val = adc_data_ptr->value;
NumberOfChars = ltoa(air_pos_val,(char *)command);
sciDisplayText(sciREGx, (uint8_t*)"AIR_POS: 0x", sizeof("AIR_POS: 0x"));
break;
default:
sciDisplayText(sciREGx, (uint8_t*)"ADC ERROR", sizeof("ADC ERROR"));
break;
FIFO - spnu562: 22.2.1.9.1
"One company for which I worked purchased a copy of one of the safety standards for me - a single reader license. Unfortunately, when the PDF version was downloaded, it was marked on every page with the name of the person within the company's purchasing department who had actually placed the order. Strictly, only that person was allowed to read it, and I was not allowed to look at it."
Are there any open safety standards, or otherwise to compete with the iec/iso standards? If not why not.
HL_Notification.c:
/* USER CODE BEGIN (11) */
extern void gioInterruptHandler();
/* USER CODE END */
#pragma WEAK(gioNotification)
void gioNotification(gioPORT_t *port, uint32 bit)
/* enter user code between the USER CODE BEGIN and USER CODE END. */
/* USER CODE BEGIN (22) */
/* USER CODE END */
HL_Sys_Main.c:
/* USER CODE BEGIN (2) */
/* Choosing the SCI module used depending upon the device HDK */
#define sciREGx sciREG1
void sciDisplayText (sciBASE_t *sci, uint8_t *text,uint32_t length);
/* USER CODE END */
/* USER CODE BEGIN (4) */
void sciDisplayText(sciBASE_t *sci, uint8_t *text,uint32_t length)
while(length--)
while ((sci->FLR & 0x4) == 4); /* wait until busy */
sciSendByte(sci,*text++); /* send out text */
void gioInterruptHandler(){
sciDisplayText(sciREGx, (uint8_t*)"INTERRUPT GENERATED", sizeof("INTERRUPT GENERATED"));
//This function is already in HL_notification.c
/* sci notification (Not used but must be provided)
void sciNotification(sciBASE_t *sci, uint32_t flags)
return;
/* USER CODE END */
#include "HL_reg_het.h"
//input by default
Run_Select = gioGetBit(hetPORT1, 24);
