1Step 1
- Open push button back
- Remove circuit board
- Remove battery retention bracket
- Using soldering iron and solder sucker, remove button
- Bend normally open leads on reed switch to match the holes for the button
- Insert switch and solder in
- Re-attach battery bracket, add some hot glue to the back of the screws to help them stay in place if required
- Insert battery and test with magnet
- Insert circuit board into existing chime, hot glue or otherwise attach it
- Attach magnet to a part of the chime that passes the reed switch when used, hot glue or otherwise
- Test!
