Maximizing usefulness of space provided by frame
A project log for Printrbot 'SuperSize Me" Mod
Transforming the humble 150x150x150mm stock print bed of a printrbot simple metal to a whopping 500x500x150mm
kendoken.do 01/04/2016 at 14:540 Comments
Looking at ways to maximize the usefulness of the space provided by the stability frame.
To the right of the machine, the space provided by the frame will accommodate the power supply needed to power two heat beds, the hot end and all motors etc.
To the left, I am looking at ways to mount a filament spool holder to the frame. The weight of the filament will help to stabilize the unit against X-Axis movement of the bed.
