Everything except the bed...
A project log for Printrbot 'SuperSize Me" Mod
Transforming the humble 150x150x150mm stock print bed of a printrbot simple metal to a whopping 500x500x150mm
kendoken.do 01/13/2016 at 05:340 Comments
I have acquired most of the bits I need to dig in to this project. To really get going, I need to begin the dis-assembly. I am a little apprehensive to dig in as I do not have a back up printer for printing the bits that will invariably come up... So I have come up with a stop-gap. I have already printed off some x-ends that are sized to fit the linear rails of the x-axis and I can put these anywhere along the x, connected to my existing print bed, which will be handy because I am waiting on the manufacture of a new aluminum super-sized bed.
Frame construction is underway.
As for the z-axis, I printed out a coupler to accommodate my larger diameter threaded rod. The diameter of the original rod of the printrbot was 6mm, my new 600mm rod is 8mm. Not a great pic...
