battery box 2.STLexternally mounted battery box because its a ball ache taking your rover apart every time the batteries die.Standard Tesselated Geometry - 289.14 kB - 04/08/2016 at 10:06 |
line_sense1.inofirst go at taking readings from analog sensor array. the two sensors disabled by // dont work properly but i left the code in. Also, there is a big delay between readings so it is easy to see what is happening in serial monitor.ino - 2.38 kB - 04/02/2016 at 12:49 |
analogpwmconcept.inoarduino sketch to explore analogue read and analogue write commands. its not perfect but it works...ino - 939.00 bytes - 02/24/2016 at 14:12 |
teensy holder v4.3.STLMount for a teensy 3.1. Teensy can be mounted both ways up, 3.2mm mounting holes fit raspberry pi 2 (length and width), also holes 10mm apart and 20mm apart.Standard Tesselated Geometry - 655.06 kB - 02/19/2016 at 14:28 |
dagu mounting board.STLA mounting board for a raspberry Pi 2 B and an L298 driver to be mounted on a dagu rover chassis. also fits a 4xaa battery box or one of the powerpacks from ryanteck.Microsoft Trust UI Provider - Certificate Trust Link - 468.93 kB - 02/02/2016 at 10:14 |
