PiFold Tie Edition
A project log for PiFold
PiZero+CustomAccessPoint+CaptivePortal+AudioStreaming+PiFM+Voip in a wallet. Cash, Cache and Content. (optional Solar Charger)
tomwsmftomwsmf 02/16/2016 at 02:070 Comments
Suiting up for interviews gave me the idea of using the otherwise unused neck ornament for something different...thus the PiFold Tie Edition.
It required a bit of destitching and placement of clasp/hidden duct tape but it did work. Interesting side benefit, wiring the FM antenna thru the full run of the tie. If i were to do this up proper i would look into an easy to insert pouch solution .
End result, the swagger and sway of the tie was greatly changed. The first time your tie Clunks against a desk it will make you stop for a bit. Not sure I would wear this to any but the coolest/savvy of interviews but as an option it was a fun alternate application.
If I were more fashionable I could see this being a great addition to a cummerbund.
'We are the goon squad and we are coming to town, beep beep"
