Android based MAME arcade mini-cab build
View all 12 components
This is the test run we took part way through
After some time on forced fed AC power the battery gave up and force shutdown the unit, we removed the battery to compensate
We hacked AC power direct to the board due to a dodgy connection in the socket
Cornflake arcade proto
Some additional pictures I couldn't add to the gallery, wiring and finished product
View all 4 project logs
davedarko
Alex Krasowski
Kumar, Abhishek
Thijs Koppen
Yes, delete it Cancel
You are about to report the project "MAME Cablet - Android Tablet MAME cab.", please tell us the reason.
