A few days back, my friend called me who had just bought a new Cricut machine. Her name is Ria, and she was a little anxious about setting up her new Cricut machine for the first time. Since I’m a Cricut user and a professional DIYer, I helped her with the Cricut setup on computer. Just like my friend, there are many users out there who are conscious about their Cricut setup. Hence, I’m writing this blog to tell you everything that I told my friend to help her.
I share my best crafts with my readers, and it makes me happy. When I get queries on my social media accounts, I get excited to answer each one of them. And the best type of answer is writing a blog. Here, you will get to know everything about a Cricut machine setup on a Windows and Mac computer. So, let’s start here!
Minimum System Requirements for Cricut Machine Setup
The first thing you all keep in mind is that your Cricut machine runs with a special software called Cricut Design Space. You’ll have to install this software on your computer in order to use your Cricut and design anything you want.
Moreover, when you’re installing the Cricut software, you have to ensure that your system is compatible with it. Below, I’m mentioning some minimum system requirements that your system should have. Only you can proceed with the Cricut setup on computer.
For Windows
- System version- Windows 10 or the latest
- RAM- 4GB
- CPU- Intel Dual Core/AMD Processor
- Connectivity- USB and Bluetooth
- Resolution- At least 1024 x 768 px
For Mac
- System version- macOS 11 or the latest
- RAM- 4GB
- CPU- 1.83 GHz
- Disk storage- 2GB
When you know about the minimum system requirements, the Cricut setup on a PC becomes easier.
Download & Install Cricut Design Space on a Computer
Before getting ahead with the Cricut setup on computer, let’s learn to download and install the Cricut app. Check out the procedures below.
Windows
Explore the steps below to download and install the Cricut software on your Windows computer. Check them out here.
- In the beginning, open an internet browser and navigate to www.cricut.com setup login.
- Now, tick the checkbox to accept the Cricut Terms of Use and click on the Download button.
- After that, let the software download and save into your Downloads folder.
- When your app is downloaded successfully, move on to your folder and double-click on your file.
- Next, allow the installation process when your window asks.
- Lastly, sign in to your Cricut ID using the Cricut login details.
Finally, your Windows PC has the Cricut Design software to start designing with your machine.
Mac
Check the steps below to learn how to download the Cricut Design Space on a Mac computer. Then, you can proceed with the Cricut setup on computer.
- To start, head to an internet browser and search for the design.cricut.com.
- Now, tick the box to accept Cricut Terms of Use and hit the Download button.
- After that, allow your system to download the software and save it into a folder.
- Then, open your Downloads folder and double-click on your Design Space file.
- Next, drag the Design Space icon to the Applications folder and allow the installation.
- Under the Applications folder, double-click on the Design Space file to open it.
- When your Mac computer asks you to open the app, choose the Open button to proceed.
- Finally, sign in or log in to your Cricut account using the Cricut login ID.
Now, you can enjoy the Cricut Design Space software to start creating your unique designs and beautiful projects.
Cricut Setup on Computer (Windows and Mac)
Here is the final part: Cricut setup for beginners. Check the steps below to setup your Cricut machine on your computer.
Windows
After checking the minimum system requirements for Windows PC, you can finally move ahead to setup your Cricut on Windows. I’m using the Bluetooth connection to connect the devices together. Check the steps below.
- To start, head to the Devices option from Settings on your PC.
- Now, check if the Bluetooth option is ON or not.
- If not, you need to enable Bluetooth and click on the “Add Bluetooth or other device” option.
- After that, your PC will start looking for the available devices.
- When you see your Cricut model in the list, click on it.
- Next, the Bluetooth connection process is complete.
That’s it for your Cricut setup on a Windows computer. Now, let’s explore the steps for a Mac computer.
Mac
After looking at the Cricut setup on Windows, it’s time to check the steps involved in setup on a Mac computer. Check the steps below.
- To start, enable your Cricut product and keep it near to your Mac device.
- Then, go to the System Preferences under the Apple menu.
- After that, tap on the Bluetooth option.
- Now, verify if the Bluetooth option is ON and select your Cricut model from the list of available devices.
- Next, when you need to enter the PIN code, enter “0000” in the given field.
- At last, you’ll see both of your devices paired via Bluetooth connection.
These are the simplified steps for the Cricut setup on a computer. Now, you’re good to go with your Cricut machine and create anything you want.
FAQs
How Do I Setup My Cricut on Mobile Devices?
Connecting Cricut to mobile devices is a simple process; check here:
- In the first step, connect your Cricut product to a power supply.
- Connect your mobile device to your Cricut.
- You can select either a USB or Bluetooth connection option.
- After that, search for the Download button and click on it.
- Then, get the Cricut software on your device.
- Next, open the Design Space software.
- Now, navigate to cricut.com/setup and make an account.
- Lastly, sign in with the Cricut ID details.
- Finally, click on the Machine Setup option.
Is Cricut Machine Compatible With Windows 10?
Yes, the Cricut machine is compatible with Windows 10 and all the latest versions. You can get the Cricut app on a Windows 10 PC and go ahead with the designing process such as uploading the designs or creating unique projects and much more.
Do I Have to Pay for Cricut Design Space?
Absolutely not. This software is from Cricut, which is completely free for beginners as well as existing users. You can get this software from Cricut’s official website for free. In the free version, you’ll get unlimited things to explore, such as a design library, free templates, texts, fonts, and many more. However, there is a subscription plan known as Cricut Access that you can consider if you want premium features for professional crafting.
Visit: install cricut design space app cricut create connect to computer
Source: https://desincricut.wordpress.com/2024/04/24/cricut-setup-on-computer-a-guide-for-windows-and-mac/
