Turns out that the Pi display has a better viewing angle from one direction than the other. The Pi Foundation flipped the display to account for this, assuming that the user would be looking down on the display from above.
In my case I think the user will be looking from 'below', so turning the display over makes sense. Which means I don't have to lengthen the jumper wires, but I do need to make some modifications to the mounting hole positions and screen cutout.
I chose this power source as it can provide 5v via the USB connector, but also has onboard solder pads to provide 5v, 9v and 12v which might be useful for projects
I had an unused drill bit case and a Raspberry Pi, so put them together with some other components to make a laptop aimed at makers.
I looked around for a supplier of the drill bit case without the drills, but can't find one. You can get the case and 99 drill for less than a tenner on eBay anyway.
The lid isn't deep enough, you're right. At least with the driver board attached to the back of th screen, anyway, and it would be a lot of trouble to mount the driver separately - the connecting ribbon cable is very short!
Seems like it would have been natural to mount the screen in the lid so it could be used like a laptop. Any reason why you chose to put the screen in the base? Maybe the lid isn't deep enough?
