mPmL_basicLogger_works_2018-10-03_2055.zip
Just a first version of the logger-code which works. Its far from perfect and even more far from done. But hey, it works for now.
Nev revisions coming soon!
x-zip-compressed - 9.21 kB - 10/03/2018 at 19:16
Download
FirstDemo.mp4
Quick demo showing an early stage of the logger.
MPEG-4 Video - 31.69 MB - 10/01/2018 at 12:59
Download
mPmL_EEPROM_test.zip
code to read temperatures from the TMP11x sensor and write three blocks to the EEPROM. It reads them back over serial to verify your data
x-zip-compressed - 2.47 kB - 09/29/2018 at 10:37
Download
mPmL_setRTC_over_Serial.zip
code to set the DS3231M RTC. Uses https://github.com/JChristensen/DS3232RTC. See examples from that library to use/set the alarms etc as well!
x-zip-compressed - 2.13 kB - 09/23/2018 at 08:13
Download
mPmL_BlinkPowerDown.zip
code to test the onboard LED. features rocketscreams low power library to save precious power while doing nothing between LED flashes :)
x-zip-compressed - 1.06 kB - 09/22/2018 at 15:04
Download
mPmL_TMP112_onboard.zip
code to test the onboard TMP11x temperature sensor (and externally connected ones)
x-zip-compressed - 1.61 kB - 09/22/2018 at 14:56
Download
mPmL_final_correctSilkscreen.zip
Error corrected: D5, D6 were labeled as D9, D10.
KiCAD 4.0.7 files, Gerbers, circuit diagram as PDF.
x-zip-compressed - 233.60 kB - 08/27/2018 at 13:15
Download
