4 Input Exander V2.zipKiCad Schematic and PCBapplication/x-zip-compressed - 46.56 kB - 06/16/2020 at 08:25 |
PushButton STLs.zipPrintable Case - Includes STLs and 3MF files for some partsThe "Case Front.stl" has two options for the LED lenses. For single extruder you can print "Case Front.stl" and then 4x "Lens - Push Fit.stl" and insert them manually. If you have access to a multi-extruder printer then you can use "Lens - Print In Place.stl" to have them printed together. application/x-zip-compressed - 331.75 kB - 06/16/2020 at 08:24 |
Audio_Input_Selector.inoArduino listing for the system- 6.63 kB - 05/28/2019 at 21:06 |
Audio Selector - Rotary Switch.skp3D Printable case for using rotary switch selectorSSEYO Koan Play File - 418.14 kB - 05/28/2019 at 21:34 |
