NN_MEMRISTOR.zipKicad files for the memristor.x-zip-compressed - 201.18 kB - 05/03/2020 at 23:38 |
NN.schSensor array schematicsch - 21.98 kB - 05/03/2020 at 23:00 |
NN.kicad_pcbSensor array pcb file.kicad_pcb - 182.96 kB - 05/03/2020 at 23:00 |
SuccesfulSimulationDiodes.circuitjs.txtFasltad circuit simulation for digit 0.plain - 5.18 kB - 05/03/2020 at 20:07 |
DiscreteComponentPrototype.RR script to test the performance of the final prototype.r - 8.56 kB - 04/07/2020 at 03:10 |
TellMeTheNumber11.inoArduino IDE file to measure and push to serial the measured values so that they can be read by RStudio.ino - 1.24 kB - 04/06/2020 at 00:17 |
Prorotyping.RTools to test the prototype using a micro-controller.r - 7.67 kB - 04/06/2020 at 00:16 |
MinimumModel.RR file to evaluate the minimum model.r - 3.48 kB - 04/06/2020 at 00:16 |
MinimumSensor.RR file to reduce the dataset pixel density and evaluate a decision tree model accuracy based on the new images.r - 2.16 kB - 03/29/2020 at 09:05 |
LoadMnist.RLoading the MNIST dataset onto RStudior - 1.44 kB - 03/29/2020 at 09:05 |
