Bus Linker Top.stl
Bus Linker Housing. Top Portion.
You'll need 2 of the 24mm M3 screws, and 2 compatible Nuts - or you could use mini zip ties on these two parts if you like.
Standard Tesselated Geometry - 46.18 kB - 08/20/2020 at 21:58
Download
Bus Linker Bottom.stl
Bus Linker Housing, bottom portion.
Standard Tesselated Geometry - 60.24 kB - 08/20/2020 at 21:58
Download
FloorSupport.stl
Print two of these to support the Plex Glass floor of the rover, they go in the middle on both right and left sides, and use the 16mm M3 screws & Nuts we have been using.
Standard Tesselated Geometry - 33.38 kB - 08/03/2020 at 22:53
Download
Servo Bracket Final v2.stl
The original one uses two screws into the servo bracket to mount the bracket to the wall and mount the servo to the bracket. That design is not sound, this one uses slots for proper mounting, and a clamp for holding the servo.
Standard Tesselated Geometry - 57.11 kB - 07/27/2020 at 06:18
Download
DiffCenterJoint v1.stl
The original one is the wrong size. I made this one, it was a little tight so I needed to sand it a little with a fine sand paper, worked perfect after that.
Standard Tesselated Geometry - 224.79 kB - 07/27/2020 at 06:17
Download
DiffTopMountFixed v1.stl
The original one is the wrong size. I made this one, and it works with the bottom one that I also made.
Standard Tesselated Geometry - 126.64 kB - 07/27/2020 at 06:16
Download
DiffBottomBracketFixed v1.stl
The original one is the wrong size. I made this one and it also mounts a little different.
Standard Tesselated Geometry - 96.96 kB - 07/27/2020 at 06:15
Download
