Tetrinsic [gd0041]
A continuous, motorised slider that is force sensitive, haptic, UV self-sterilising and water resistant.
Public Chat
To get the most bandwidth out of my dual hands, I'm designing an input component that can obtain more data than a standard keyboard switch.
Tetrinsic is designed to be used for input devices such as Tetent [gd0090].
Media
Inspiration and/or examples of working principle
I found this video which shows how the slider would ideally perform, just that you can press down on it and it can be set to allow movement "infinitely" in either direction.
Tetrinsic is the merge of the above motorized sliding potentiometer and the SmartKnob View:
The visible area is designed to be as minimalist as possible, so that things like an LCD backlight can be used for designs:
The cool thing about Tetrinsic is that you don't have to remove a magnetic top layer (as seen in Flux) or hotswap out the switches (on a more traditional keyboard) if you want to change tactility. Just tune it to your precise tastes in software.
Navigation
The title tag system is explained here, and the table is updated when a change occurs. Notable logs have bold L# text.
L1
[M] Test log 1
L2
[P] Printed concept in resin
L3
[M] Wider and shorter
L4
[R] Redesign options
L5
[A][R] Motorized Switches
L6
[T] Force sensor instead of magnets?!
L7
[M] Switch mounting hardware
L8
[P][M][R] Sensors and drivers
L9
[R] Sourcing chips
L10
[T] Other uses of Tetrinsic
L11
[M][T] PCB concept (and project name)
L12
[M] PCB Schematic
L13
[T] PCB schematic... fails.
L14
[M] I/O Expander
L15
[M] Direct ADC connection
L16
[T] Using a microcontroller
L17
[T] Tetrinsic as master control
L18
[M] Starting the PCB
L19
[M] Populated MCU
L20
[M] PCB Rerouting
L21
[M] 1000 Pages
L22
[M] Motor Pad
L23
[M] 40mm Long
L24
[M] PCB slowly being rerouted
L25
[P] Micro Motor and Belt
L26
[M] Updated CAD issues
L27
[T] Thinner solution idea
L28
[T] Ball chains?
L29
[T] To LED or not to LED...
L30
[T] TFT, angle sensor and 16MB flash
L31
[M] The All New Tetrinsic 2.0: Initial concept
L32
[M] Load Cell Simulations
L33
[T] USB Connection?
L34
[R] Looking at the start of Plover
L35
[P] Chain in a channel
L36
[A] Mining for a solution... ends, in 30 days.
L37
[T] Even thinner? Solution required.
L38
[T] Current Tetent layout
L39
[T] Focus on obtaining TestCut?
L40
[M][R] CAD redesign... started.
L41
[B][M] Initial BOM made
L42
[M] Tetrinsic Gen 3X1 Concept
L43
[M] Drawing a theoretical layout
L44
[T] Bolt reinforcement under LCD?
L45
[T] Sloped Tetrinsics?
L46
[T] Space for an off-the-shelf load cell?
L47
[T] Mounting options
L48
[M] Sculpting a look
L49
[M] Mining for a flat-top solution
L50
[T] Joysticks for thumbs?
L51
[R] Taking load cells out of pocket scales
L52
[A] A solution... failed, in the time provided.
L53
[T] Cutting the load cell
L54
[P] LCD and Steel Tubes
L55
[T] LCD-down mounting
L56
[P] Small 500g Precision Scale Teardown
L57
[M] Load cell update
L58
[M] Detailed modelling started: LCD Holder
L59
[M][T] ESP32-S3 MINI and other changes
L60
[R][T] Plans going forward
L61
[M] Slow foundations
L62
[M] Chain Pathway
L63
[M] Chain aligned
L64
[M] PCB on side?
L65
[L] First symbol in Fusion360 Electronics
L66
[L] ADC schematic entry
L67
[L] Created BMI160 footprint
L68
[T] Tetrinsic Taic: Solar panel variant
L69
[L] BMI160
L70
[M] Solar Cells
L71
[M] Photovoltaic cell implemented
L72
[R] Solar Cells: Polycrystaline and Amorphous
L73
[L] MP6543 BLDC Controller
L74
[L] ESP32-S3-MINI-1U component
L75
[L] Pins and the GPIO Matrix
L76
[L] LBS147TC-IG01 (1.47" LCD) Pad
L77
[L] 580KV Motor Pad
L78
[L] Tetrinsic Pad
L79
[L] MIP LCD and Not Enough Pins
L80
[L] BMI160 3D package and 74HC595 output extension
L81
[L] Expansion Pins
L82
[T] Looking ahead: USB Type-C system
L83
[R] Are better components now available?
L84
[L] DRV8311P Motor Controller Component
L85
[T] Eliminate interconnects?
L86
[L] Updated Schematic with New Components
L87
[L] The start of the PCB
L88
[L] Component alignment and solar pads
L89
[L] Vias (and other DRC things)
L90
[L] The Magic of QuickRoute Airwire
L91
[L] Milestone: PCB Fully Connected
L92
[L] 3DPCB
L93
[L][R] Trace Polishing, USB and the AAT101 capacitor
L94
[L][T] PCB pre-assembled with passives?
L95
[L] Increased vias to 0.3 : 0.45mm
L96
[L] Silkscreen Issues
L97
[M] Single Path 3.2mm Edition
L98
[B][M] Pulley, sprocket, slider mount and BOM
L99
[R] LT6911C HDMI to MIPI in a QFN Package?
L100
[P] 3.2mm Ball Chain (and 100th log)
L101
[P][T] Scribe Tool,...
  • [M][R] Custom 16mm Slotless?
    kelvinA12 hours ago 0 comments
    From the centre outwards, you've got:
    • 2.5mm shaft
    • 2 pole pair magnet of 8mm diameter
    • 0.4mm air gap
    • 0.4mm spiral vase mode housing print (in PBT ideally, but ABS should be OK)
    • The space for the copper (1.805mm)
      • Coincidentally similar to the 1.85mm copper height in the 580KV motor.
    • Tolerance gap of 0.2mm
    • Outer lamination yoke that is 1.2mm.
      • I opened up the 580KV motor I got to find out what size was used.
    Copper foil?
    You might be wondering what this is. This is the approximation of 3mm copper foil stacked on itself. Since copper smaller than the magnet width does not provide any torque (so I've heard), it makes more sense for the tape to hug the edges.
    Assuming
    • a 0.06mm thick tape, of which 0.03mm is copper
    • 90mm stator / rotor length
    • 11mm on each end to connect the straights together
    I got a copper tape length of 6060mm (6m) and a resistance of 12.1 ohms., which isn't great but kind of tracks compared to the 8.2ohm, $32 motor that looks like it's probably 55mm in total length and thus probably has a 45mm long stator. It obviously doesn't help that less than 50% of the CSA is conductive.
    Copper wire
    For the more traditional approach, it looks like there will be at least 15 * 8 = 120 turns (or 60 if I decide to double-up) using 0.2mm (32AWG) wire. Estimating for the extra space filling, it's probably going to be at or close to the 130 turns in the paper. It would also seem that a 3-pole-pair rotor would be ideal for this design.
    Assuming that the average length to connect the straights is 9.4mm and that 138 turns are used, I get 27434.4mm (27.4m) per coil, which corresponds I get 14.7 ohms.
    Is that high? Maybe? However, if this design -- with rotor of length 90mm and diameter 8mm -- can match the 75mN.m obtained with the paper's motor (rotor of length 25mm and diameter 11.5mm), The minimum driving voltage and power consumption would suffice:
    If anything, I worry that the Kt would be too high and the minimum drive voltage would be lower than 6V. Additionally, manually winding dozens of coils for over 100 turns each sounds like it would be laborious. I could always double up the 0.2mm wire, but it seems that it would just be easier to work with 0.25mm wire:
    Here, it seems that at least 80 turns would be present, probably something like 82. If my tolerances are good, I could probably fit a 7th row and perhaps get to 90 turns. For 82, the total wire length is 16301.6m and the resistance is 5.4 ohms.
    Quick finger tests
    So, just to make sure I'm on the correct page, I put my scale against the wall and pushed my fingernail for Finger2-4 (see below) and the max reading across the tests were about 300g, thus I'm correct in aiming for 30mN virtual-endstop force.
    Secondly, I played some music, slowed down so that 1/8th of a beat corresponded to the time it took my finger to move 50mm. This is because 16 x PI = 50.3mm. Then, I used an online BPM tapper to get 1/4th, which was 220BPM. Thus, the top RPM I expect to see on the motor is >= 440.
    Tube instead of laminations?
    The reason I want to know the top RPM specifically is because eddy current losses are a result of how fast the magnetic flux is changing. Considering that, unlike 99.9% of motor applications, this motor is working at no / low speeds of essentially 500RPM max (unlike the 10K that the authors of the paper called "low speed"), I'm wondering if the eddy current losses will be low enough to use a tube of magnet-permeable material.
    Stainless Steel 304 could be a good choice, as it's readily available and, unlike things like mild steel, doesn't corrode in contact with water. I don't know if magnetic PLA is more or less magnetically permeable, but stainless steel probably would do a better job of dissipating heat.
    The paper says that the magnetic "air-gap" is essentially from the rotor magnet to the outer yoke and thus should be minimised, and that it's a balancing act between that and...
  • [E3][R] Frameless VS Slotless BLDC
    kelvinA2 days ago 0 comments
    2806 Frameless BLDC
    1656 Slotless Motor
    Introduction
    So I went over to the SmartKnob View discord to try and find some answers on motor options. The user K(at)B (the one behind the Ratchet H1)  noted the potential implications of airlines likely not wanting to take belts that emit magnetic fields. I also had the concern that these magnetic fields are likely to interfere, especially if a Tentrinsic for the thumb is used.
    He then suggested this:
    In practice, I'd expect to need 4 gears, not the two shown in the 3D sketch; 2 plastic 0.5M bevel gears and then 2 more gears that transfer the load to the pulley for the belt. He also suggested FSRs, and there happen to be long ones for an ok price, especially since an MCU ADC would be able to read it instead of requiring a fast but expensive 24-bit ADC.
    This video shows that scissors can be used to cut the FSR to the required length if needed:
    [Apr 27: Edit 3]
    It seems that there's an even more ideal sensor, that works in the 20 - 500g range and is 10mm wide, which are both attributes that I'm looking for. There's also a schematic which essentially says that I can put this in a voltage divider along with a 10kOhm resistor and feed the output voltage to an MCU.
    [End of Edit 3]
    Thus, this was the start of searching for my motor options. Since 18mm Tetrinsic spacing seems more like "the standard value", and many motors seemed to be 16mm diameter, it makes sense to set the new maximum width of a solution to about 16-17mm.
    Things I learned about motors
    I think it's best if I fist provide some reference material that better helped me understand what to be thinking about when looking for a motor:
    • Lower KV motors are designed to be run at lower speeds and more likely to have minimal cogging.
    • KV seems almost irrelevant for coreless / slotless motors that have 0 cogging.
    • Torque for this application needs to provide 100 - 150gf continuously and over 300gf peak.
      • This is because the former is needed when emulating an analog stick. This site suggests that 75g is "standard", 100g is "hard" and 150g is "strong". Due to potential frictional losses, it's probably better to slightly overspec the standard torque, and that's why I'm aiming for 100gf minimum.
      • The latter is to emulate physical limit stops, and isn't expected that the motor will need to produce this torque for more than about 500ms.
    • Torque is proportional to current. That's it. Just current.
      • It was a bit surprising when I found this out, hence the emphasis.
    • The voltage determines the maximum RPM of the motor. This is due to back-EMF generated when the motor is spinning. If it's not spinning, there's no back EMF.
    • The voltage and phase resistance determines the max current that can be sent to the motor. It seems that the aim is to get a low PR as that means lower voltage, which results in exponentially less power used.
    • It seems that the torque constant (Kt), mN.m/A, is more important than the voltage constant (Kv).
      • Smaller wire = more coils = lower Kv, but less current can go though said wire so the effect is cancelled out and thus Kv has no real connection to Kt.
    Frameless
    I noticed that, from looking at motors found for the Smartknob View, there were a few motors that were shorter than 15mm. The 2204 260KV motor, for example, is 13mm. However, looking at images inside the motor, it seemed that there was a notable amount of unused space inside. Some time later, I came across frameless motors, where just the stator and rotor magnets are sold:
    Long story short, these are the only options available, but the good news is that I just need the 1 solution and the WK2806 seems to provide!
    • Phase resistance: 5 Ohms
    • Kv: 121
    • Nominal current: 0.81A
    • Nominal torque: 600nM.m
    • Stall current: 1.22A
    • Stall torque: 900mN.m
    Now, you may be wondering "Those seem to exceed what you need. Why not go for the 2205?". Well the issue is that the ball chain has...
  • [R] Coil All Around belt linear motor?
    kelvinA5 days ago 0 comments
    The title is a play-on-words of GAAFET, standing for Gate All Around, Field Effect Transistor.
    Now that the #Coaxial8or [gd0144] is in a bit of a break period as I wait for the new heatblock design to be fabricated and arrive, I have been looking into Tetrinsic again. I still feel like if I had to choose 1 single project to "get past the post" (i.e. design, manufacture and implement into my daily life), this is it; unlike 3D printers and XR glasses, I unfortunatley haven't found enough information on the internet that suggests that some company would come out of "stealth mode" with a sufficient offering, and even if one did come out today, they'd most likely say it will start shipping "in months" but implications would mean that "in years" would be more accurate. On the other hand, I haven't been able to indirectly find this project through my search queries, so there could still be similar projects and solutions that I haven't come across yet.
    Anyway, I came across this video about linear shaft engineering:
    My strategy I thought up back in September 2023 was the U-shaped linear motor, just with the coils and magnets swapped around. This aleviates the cooling drawback they mentioned, but understandably still has the drawback they mentioned where only half the magnetic flux generated by the coils used (the other half is in the opposite direction).
    The video states:
    Force (N) = Current (A) x Magnetic Flux Density (T)
     Thus, for a fixed current, more force is generated with a higher density. This also suggests that, for this application, it's better to drive the system with as low a voltage as possible.
    Looking into the DRV8311, they're just simple H bridges at the end of the day so it's not like the chip is doing anything fancy with the input voltage. Additionally, I found these answers on stackexchange. While doubling the voltage will double the torque, it would quadruple the power required. Thus, since the power for each Tetrinsic is limited to prolong battery life, and I mainly need the torque in very low - low speed situations (e.g. sub 300Hz haptics) higher voltages are actually worse, as are very thin (0.1mm) wires used to make the coil. Instead of 12V, it now sounds like it would make more sense to run everything on 3.3V, which would still allow for up to 16.5W per Tetrinsic.
    Additionally, I've read bits and pieces that should lead to improved performance, but this answer brings everything together. For example, it did seem that a thicker magnet would increase strength when reading Doubled Forces, which the user "cinaral" confirms. They also say that the thickness of wire -- thus its current carrying capacity -- roughly balance out with the amount of turns that can physically fit in the space, which sounds like a foil coil is still the more ideal strategy from a heat dissipation and manufacturing standpoint.
    As mentioned in the video, magnets emit their field in all directions. What wasn't mentioned, but probably just as important, is that the coil has it's highest flux density in its centre:
    Source
    The video proposes a shaft where like-poles are pressed together with no airgap inbetween:
    This configuration is probably to force the flux outwards from the magnets:
    Source
    It likely is also so that the shaft doesn't just act as one massive magnet. With this in mind, the plan is to move from a 10x3x2 to a 10x3x3 magnet so that I can place them in this configuration.
    Manufacture
    I already knew about linear shaft motors (but not their benefits over U-shaped ones), but the issue is that I still need to actually make a belt or a motor or both. With the U-shape solution, both of these can be made separately, wheras with a coil-all-around solution, one would have to be made in-situ.
    Additionally, I need to consider how individual magnets will come together to form a belt in the first place. Since the magnets are relatively small and the belt...
  • [A] Details page before 14 Jan 2024
    kelvinA01/14/2024 at 12:46 0 comments
    Details
    This project is intended for #Tetent [gd0090], #Tetrescent [gd0150] and #Leti [gd0149]. Tetrinsic is the "input element" and in the same category as a keyboard switch or controller joystick.
    Notable Tetent projects, sorted by project log count:
    Examples of Similar Products
    Concept History
    Tetrinsic Concept3.2X2 (interwoven, dual BLDC motors)
    Unfortunately, Concept3.2 had a turning radius that was too ambitious. Thus, on August 10th 2023, it was decided that a redesigned Tetrinsic with dual motors and the ability to weave the Thumb Tetrinsic around the FingerN Tetrinsics would be the best strategy forward. This also allowed anything to be placed inside through the loop.
    From Aug 25th, the focus has been on designing for #Tetrescent [gd0150], where a solar cell is placed inside said loop.
    Tetrinsic Concept3.2 (single 3.2mm chain, dual TFT displays)
    After creating the new Tetrinsic PCB that uses the ESP32-S3-MINI-1U, on June 30th 2023 I eventually decided to increase the size of the ball chain to 3.2mm, make it so that there is only one path that is exposed and, to increase the usable length : body ratio, doubled the screens. This is the first concept CAD model that was electromechanically complete, made on July 18th 2023.
    Tetrinsic Gen 2X2 (smooth top wedge shape)
    Development started on Jan 12 2023 and moves the components so that the load cell is parallel with the LCD and that the motor does not protrude the top surface. The aesthetic is further improved whilst improving the ability to slide into a pocket (for TimerSpy). This was first called Tetrinsic Concept4.
    I then spent subsequent weeks turning this concept into a more fully-designed prototype, and added a photovoltaic solar cell variant. This concept was using 2.4mm ball-chain that slid on 1mm diameter stainless steel tubes. The above is more-or-less as far as I got before I started work on the PCB. Unfortunately, the design got a bit too large such that I couldn't come up with a solution for #Tetent TimerSpy [gd0136].
    Tetrinsic Gen 3X1 (wedge shape)
    The shape is to allow Tetrinsic to be mouned on the back of my hands and slide into pockets for TimerSpy and fit into the square prism shape of TestCut. A notable improvement is that an off-the-shelf load cell can be used, saving on build time, increasing precision and reducing displacement.
    Development started from Jan 4 2023.
    Tetrinsic 2.0 (LCD backlit, dual 2mm ball chain)
    Tetrinsic 2.0 is an internal name to refer to the redesigned version I started developing from Dec 26 2022. It's not actually the second version of Tetrinsic, since I haven't actually made a first one yet. Think of it as Tetrinsic 2.0mm.
    This redesign should bring advantages such as lower sliding resistance, shorter allowable finger offset distance, shorter height, a full-bridge-configuration pressure sensor instead of an iffy half-bridge, a much more popular microcontroller (RP2040 vs M032) (thus, better software support) with more RAM and FLASH memory and,...
  • [E2][X] Plotting finger movements
    kelvinA12/23/2023 at 20:56 0 comments
    So I spent maybe 2 hours setting up the groundwork of this excel spreadsheet and then maybe 15 minutes actually puttinging in some values. This spreadsheet assumes I'm using #Tetrescent [gd0150] and in a mirrored (aka vertical) mode where for both sides, the placement of characters is Finger1->Finger4.
    I've tried plotting the position and force level in the black chart, and the change in position and force level in the white chart. For the most part, I can't really gather any insights so far. Perhaps it's just because I've only input the first sentence to see if I should continue or not.
    The fanciest part of the spreadsheet is the use of a lookup table, but the command LOOKUP didn't work. The good news is that we now live in the advent of AI:
    In this spreadsheet, I assume that a blank field for the char columns means no input, i.e. 0 force from fingers. Thus, my equations are:
    For position X: If the char field is blank, use the previous position
    (I'm just lifting my fingers), else find the corresponding position for the
    char:
        =IF(ISBLANK(E4), B3, INDEX($AS$2:$AS$56,MATCH(E4,$AR$2:$AR$56,0)))
    For force F: If the char field is blank, the force is 0, else find the
    corresponding force for the char:
        =IF(ISBLANK(E4), 0, INDEX($AT$2:$AT$56,MATCH(E4,$AR$2:$AR$56,0)))
     for the fingers, and
    For position X: If char is blank and the previous position was 1, go to 2,
    else if char is blank, do the same as the fingers.
        =IF(AND(R3=1,ISBLANK((U4))), 2,
        IF(ISBLANK(U4), R3, INDEX($AS$57:$AS$70,MATCH(U4,$AR$57:$AR$70,0))))
    For force F: (similar thing to the position calc and finger force calc:
        IF(ISBLANK(U4), 0, INDEX($AT$57:$AT$70,MATCH(U4,$AR$57:$AR$70,0))))
     for the dynamic spacebar thing (which could be the Thumb or Finger5). This is because the finger (in this case, Finger5) rests in the below white box of the layout:
    The user pulls back to column 1 --  similar to a trigger or that sliding, on-off toggle thing on the PSP -- and then the motor exerts a force to push the finger back to column 2. This allows me to have a virtual button without having to push down on the Tetrinsic. It's similar to how I envision the datahand-inspired layout to function.
    Now, the reason why I typed the phrase out first is so that I could also get pseudorandom typos integrated into it. For this monkeytype test, I had 2 errors. The first one has been recreated here, taking the Tetrinsic layout into account:
    The code "s1" stands for the first space option, and "bc" stands for "CTRL+Backspace".
    This typo simulates accidentally pushing too hard on Finger4.
    [24 Dec: 20:00]
    So I've spent a while learning things like the =OFFSET command, so that I could have a dynamic start-end point for the charts without having to laboriously edit tens of values. BingChat initially generated code for =INDIRECT, but then I started moving colums around to make the spreadsheet more readable and the positions didn't update in the charts.
    This is the first time I'm even realising there's a "Formulas" tab in Excel, let alone that you can name selections just like in Fusion360.
    I've moved things around so that everything is a lot more readable. Hopefully, this gives those finding out about this project a better understanding on how the typing system works.
    Then I needed another run. I decided to go with a quote this time, and despite it being 5am without having slept yet, I managed to 100-accuracy it.
    For both of these, I've assumed I'm proficient enough to realise when I can reduce finger travel, such as being able to keep Finger2 on "O" between rows 76 - 78.
    From doing this, I was able to make some slight optimisations to the layout, which can be seen below:
    It's still kind of tough to...
  • [T] Linear hall sensors and water resistance
    kelvinA12/09/2023 at 17:04 0 comments
    Hall effect sensors
    Firstly, I want to mention that @dekutree64 commented in this log from #DIY Mech/Exoskeleton suit. about his experiments on using 2 hall effect sensors in this form thread. The original poster (OP) of the thread mentioned a drawback was a "computational intensive trig operation" but deku responded with a link describing an approximation that is correct to 0.28 degrees. Now, deku's been able to get the below results, with 3.3V circuitry:
    Thus, I belive I'm going to go ahead with using 2 linear hall effect sensors for positional tracking.
    Waterproofing Tetrinsic?
    Secondly, I want to add water resistance to the list of supported features of Tetrinsic.
    I've been mulling over going the extra mile to obtain a higher solution coverage. Just as I aprieciated water resistance on full-android smartwatches, I believe water resistance would further open up the applications that Tetrinsic could be used in (for example, writing a novel in a bath or jotting down sudden ideas in the shower), as well as increase resilience against day-to-day life.
    The idea is simple, which is to encase the coils and UVC components in a resin transparent to UVC wavelengths if it exists. Something thermally conductive would be ideal.
    For the load cell, a solution may be to coat the strain guages in nail varnish or a coating specifically designed for this application.
  • [T] Face-worn input device?
    kelvinA12/04/2023 at 22:53 1 comment
    I was writing this log and then something happened and poof it went, so I have to write it all again. I must embrace the saltiness I feel.
    Moving on, I haven't been able to get around to learning how to set up and simulate electromagnetic coils for use in Tetrinsic. I just lack the time (and time security). This entire situation is a cyclic redundancy, as I want to use a Tetrinsic powered input device to research/design/document Tetrinsic.
    Conceptually, the plans I've got for #Tetrescent [gd0150] meet or exceed my needs and wants for an input device, but there is one thing that is still missing and is one of the important ones: wearability. #Tetent TimerSpy [gd0136] was when I tried solve this with a wrist or hand mounted solution, but that had its own challenges -- namely that I couldn't easily take my coat on/off and that coming up with a solution where I could enter data with both hands was difficult. Now, it seems that Tetrinsic would be too large for such a solution anyway.
    After starting my new Head Mounted Display (HMD) project, #Itinervate [gd0151], I started considering a head-mounted input device to complement it, specifically one where the active area is against the cheeks. The benefits I thought of were:
    • My hands usually rest on my cheeks when I'm thinking.
    • Each hand can reach both sides of the cheeks, as well as I can use both hands simultaneously.
    • I could increase the scope of the project to include the idea of spacial audio headphones via multiple physical speaker drivers that I had a few months ago.
      • I really want to be able to recreate the feeling of working under the speakers of a restaurant/store.
    • I've paid close attention to the aesthetics of Tetrinsic when implemented into a potential design, which is important for something that would be easily visible.
      • I'm not going to target for something "discrete" or "unnoticable" because unless it's a pair of glasses or a mask, any item worn on the head is going to be noticed.
    This is a roughly-scale sketch of what I was able to create in PowerPoint:
    Image Source
    I intend for those diagonal bends to actually be a smooth curve, so the above is more like a low-poly rendition. I'm also expecting the trailing edge to get smaller (kind of like a comet). The grey lines are Tetrinsics that have at least 90mm of stroke length (to make sure that there's enough space for both my fingers and the electromagnetic coils). Since the middle white part curves downwards and becomes shorter than this distance, I've decided to make 2 of the Tetrinsics longer and terminate those at the top of the part that covers the ear. Then there are 2 dark grey lines which represent imitation Tetrinsics (similar to fake speaker grills).
    I haven't yet considered how this is all to be mounted to the head as I want it to complement Itinervate, which I haven't yet made a concept for. All I know is that there are going to be 2 screens above natural eye level that come out from the centre.
  • [R] Electromagnetic simulators
    kelvinA09/20/2023 at 22:55 0 comments
    [20 Sep]
    I've more-or-less have the mental 3D model of the new Tetrinsic concept, but I'm not modelling any of it until I've first set up and simulated some coils. I've got at least 360 of these I need to either create or buy from a manufacturer in China (since the MOQ is likely high enough for one to take the order). I'd like to know the performance of both a foil and wire coil before I continue further.
    Ideally, I'd also like to simulate so that I can find the optimal location for the hall-effect sensors.
    All this means that I need to find and learn how to use a new simulator, as Fusion 360 doesn't do this.
    EMWorks
    The first thing I found was a webinar on linear motors:
    It seems that the force exerted on the mover is what I ultimately want to find out.
    The price of this software is "Contact Us" though.
    FEMM
    Looking into the free options, I found this forum post from 2010 that asked the community to pool together any finds on this kind of software. FEMM was mentioned, and it already looks like the kind of program I'm looking for.
    They also seem to have a lot of tutorials. Hopefully, one of those is how to get force data.
    Elmer FEM
    I then found this resource that is a list of electromagnetic simulators. In addition to coils, it seems there are simulators for PCBs and antennas that are also in this list.
    One program I found was Elmer, which seems more recent than FEMM, and I started watching this webinar:
    This part is interesting because it shows that it can support the "stranded" and "foil" types of coils. It also sounds like this programs is rather large, so it's most likely going to take a while to learn how to use it.
  • [T][R] Concept Fantastic4
    kelvinA09/03/2023 at 21:05 0 comments
    The next Tetrinsic concept was going to be "Tetrinsic Concept4", but partially because this project needed a hero and partially because I was thinking about the intro music from the 33 second mark of the Fantastic Four: Worlds Greatest Heroes as I was thinking up all the improvements I could make from Concept 3.2X2, the internal code name is "Tetrinsic Concept Fantastic4".
    The idea that forms the basis of this concept was from @RunnerPack all the way back in January, and is something I didn't really want to work on until after I actually had a proof-of-concept to test since it would involve more 3D printed / custom components. I wanted to be able to compare the off-the-shelf hardware solution to the more custom made solution.
    Now that the 580KV motor is no longer available and I know that cogging should really be 0, I'm going to have to go through with a custom motor solution. While I was at it, I wanted to see if I could increase the stroke : body length ratio.
    Initial thoughts
    I thought about a solution for about an hour, and this is what I envisioned:
    • Tetrinsic becomes a linear BLDC motor with integrated hall effect and pressure sensors.
      • Part of the reason is so that I have more space to make and place coils.
    • I move all the logic back to #Tetent [gd0090] / #Tetrescent [gd0150] like I originally planned at the start of Tetrinsic Concept1
    • The motor controller is already designed to let me bundle 4 motors to one CS pin, so I just need 2 CS pins for all 5 linear motors
    • I can use the 3 hall sensors that are sometimes installed into BLDC motors as the position encoder.
    • I only need 2 bent tubes, and the turning pulley can fit inside the loop instead of outside
      • This assumes I can create a surface that can turn on a 7mm diameter radius
    • Coils will be on the top and bottom of the linear motor section, which makes the magnetic field much more consistent and means that I don't have to worry too much about air gap
    • The belt can be printed as a "Spiralise Outer Contour" (vase mode) of TPU
      • It can also be made from a magnet-band-magnet sandwich, where 2 separate magnets are stuck on each side of a thin loop of material.
      • I later realised that this would mean that the Thumb Tetrinsic would have to be a different height than the Finger Tetrinsics so that the loop could go around them.
    • On the connector board, I can use a 5 input Sigma-Delta, 24bit ADC for the load cells and up to 5x multi-channel 16 bit adc's for the hall effect and current sensing
      • (I've been hearing multiple times that the ADC on the esp32 isn't great)
    • Encasing the top-down coils in a ferrous material should further increase the field strength between the coils and the magnet embedded belt.
    My idea is to take a linear motor like the one shown below, and swap the coils and electromagnets:
    The design shown above also looks like a scaled up version of a voice coil actuator, which can be used for haptic vibrations.
    Anyway, cogging is eliminated because there's nothing magnetic in the stator. The first time I saw the video about cogging, I didn't fully grasp it, but the thumbnail actually does a good job of showing what's actually going on:
    From the perspective of the magnets, the copper coil may as well not exist. The ferrous stator teeth it's wrapped around is a different story. Because of the gaps between the stator caps, there's actually an imbalance of attractive forces. (remember, magnetic materials are attracted to both north and south poles of magnets). I'd imagine that, to solve it, you'd either need to remove the ferrous stator entirely or design the stator such that the attractive force is equal across the entire perimeter.
    Magnets
    The first reason why Me In The Past didn't think that the embedded magnet idea would work was because I was...
  • [R] Looking for a new brushless motor
    kelvinA08/28/2023 at 08:44 0 comments
    [09:30, 28 Aug
    It first helps to define what Tetrinsic needs to be at this point in time. It needs to:
    1. Be no wider than 18mm.
    2. Use a 45mm load cell or some other precision force sensing technology.
    3. Precisely detect finger position.
    4. Provide a grippable, low resistance, linear sliding medium for the fingers and thumb, ensuring fingernail compatibility.
    5. Have a brushless motor that exerts at least 300gf at point of finger contact.
    6. Allow for the below sliding medium configuration, unless another suitable ergonomic solution is found.
    I've looked around AliExpress and there are a few motors that have a diameter of 16mm and lengths of 23mm and over.
    Of which, the one with the best KV is this 1632 motor:
    Specification:
    Voltage range: DC 8V-18V.
    Speed: 5600RPM-12000RPM.
    Motor length: 32mm.
    Motor diameter: 16mm.
    Shaft diameter: 2mm.
    Shaft length: 7mm.
    Weight: 23g
    Precision 16mm brushless motor with inner rotor, body length 32mm, the appearance of the bulk motor is somewhat scratched by transportation, the motor is relatively good quality, all aluminum alloy shell CNC processing, motor front and rear ball bearings, built-in Hall-type brushless motor.
    The rotor is composed of 4 rare earth neodymium magnets. The magnetic force is very strong. It is obvious that the reluctance of the motor shaft is rotated manually. This motor does not have a drive, so it needs an external brushless drive to run.
    The motor should be nominally used at 12V, and the measured voltage can also be used between DC 8V-18V.
    Test data:
    Voltage: 8V       No-load current: 0.08A       No-load speed: 5600RPM.
    Voltage: 12V       No-load current: 0.13A       No-load speed: 8200RPM.
    Voltage: 18V       No-load current: 0.16A       No-load speed:12000RPM.
    The RPM at 12V is 17% higher than the 580KV motor. The KV range of this inrunner motor is 700 - 667KV. It also sounds like the cogging torque of this motor is notable.
    I then watched the following:
    The summary:
    • Matching KV to the application is the most important
    • Generally, inrunners have a higher KV than outrunners
    • Inrunners can be more efficient as the windings can conduct heat through the case
    • Cogging happens in a slotted but not slotless motor [relevant video]
    • Cogging is stronger on a 6 pole motor.
    Looking in the SmartKnob discord, it seems that for a device which is supposed to dynamically create it's own dedents, cogging is understandably not toleratable. This is what the creator means when he says that a motor has no cogging:
    Even if that 1632 motor didn't sound like it had cogging so strong that the seller thought to mention it, I currently can't imagine a geometric configuration that I find acceptable.
View all 136 project logs
RunnerPack wrote 02/06/2023 at 18:22 point
(EDIT: This was supposed to be a reply to the other thread; I don't know what happened)
Well, I love blinkenlichten as much as the next guy, but if I ever made any of these, that would likely be omitted entirely or perhaps replaced by a single WS2812 LED. My ideal input device is something I never have to look at, anyway.
I didn't use the term "voice coils" but that's what a PCB motor (or, really, any electromagnetic motor) boils down to. The whole point of the magnets and (PCB) coils is to eliminate the BLDC motor for haptic/tactile feedback. As I stated, I think the hall-effect sensors would offer good enough position sensing for both motor feedback and reporting motion to the host device.
Absolute position would be easy enough to keep track of in software, and I don't see why you would need absolute positioning across power cycles in this application (although I admit I only vaguely understand the concept beyond "one slider per finger that are also analog buttons" at this point). As the "belt motor" would be coreless, I don't think cogging would be an issue.
"Are there any specific optimisations you're trying to achieve with your idea, such as footprint / price / ease of manufacturability?"
It's just a gut feeling, but I think eliminating the rotary motor & mechanics would positively affect all of these, and maybe even improve user experience. (Although I've never tried it, I'm not enthusiastic about trying to drag bead chains across an OLED with my fingertips for any length of time, with or without a 240g opposing force).
Anyway, I was just brainstorming possible alternative ways of achieving the basic idea, not trying to upend the entire project.
kelvinA wrote 02/06/2023 at 23:49 point
When I was talking about the voice coils, I intended to mean a vibration originating from underneath the entire sliding surface and not just the (PCB) motor position.
The Ahmsville Dial sounds to be the type of encoding closest to what you're describing, but it seems to also require an analog comparator chip for interrupt signals. I'd have to see if the 24-bit ADC (which I need for the load cell) has any interrupt features I could use.
The main issue I have with the idea is the non-automated manufacture of 10 magnet-infused belts at even basic mouse resolution of 800dpi, or 31 dots per millimeter. I'll calculate it now:
For a 10mm diameter, one "dot" of distance is 0.03226mm, the chord angle is 0.369672 and thus the minimum required steps per revolution is 974. Hm... that sounds kind of manageable actually. I'll assume 1.5x1.5x1.5mm square magnets since they'd be stronger than the 1mm^3 ones and I'd need less of them to cover the approx 130mm length. Assuming a 1.5mm gap between magnets, I'd need 43 magnets in the belt, where about 5 would fit in the motor semicircle and the equivalent full circle encoder would have 10 magnets. Going off the Ahmsville provided formulae [https://youtu.be/_1tGosBLRB0?t=147], base resolution would be 20, but the hall effect sensors can detect a range of values. Practical resolution was found to be 25% of the theoretical resolution taking this range into account, for a 64.5X multiplier. Thus the resolution in this system is 1290. It might work, but I've only really used mice with >=2000 DPI.
Still not a fan of accurately positioning and casting 430 tiny magnets though, and it still requires the stator to be able to somehow generate 240gf. The magnets also have a higher mass -- and as such, inertia -- which would have to be overcome for any haptics to be felt.
RunnerPack wrote 02/07/2023 at 15:33 point
Yes, the assembly process has always been my greatest concern.  My first thought was a plastic fixture to hold the ring of magnets while the outside of the belt is cast, then transferring that to another mold to do the inside of the belt.
It's too bad one can't get the raw, sintered, plated NdFeB pills and magnetize them in-situ, but I think they have to be magnetized before sintering.
Oh, well, probably not worth pursuing, then.  Thanks for entertaining the idea.
kelvinA wrote 02/07/2023 at 17:38 point
I've been scanning the interwebs for concept ideas, so of course I'm going to explore any idea I just get given.
A 3D printer like the SecSavr Suspense would be able to print the belt (in a silicone-like material) and pick+place the magnets into place mid-print, as well as a good-enough-for-me chance of being able to print the stator too, but I'm making Tetrinsic to use in Tetent to create the Suspense much faster than I'd otherwise be able to; that's a circular dependency.
A jig could be used that accepts 2 magnet stacks (where one is the opposite polarity as the other) and it pushes 2 magnets into mid-print voids at a time.
kelvinA wrote 08/29/2023 at 15:53 point
I think I might need to look further into this potential solution, now that the motor I've been designing around has disappeared from AliExpress and the SmartKnob project still has trouble sourcing low-cogging motors.
RunnerPack wrote 02/01/2023 at 20:26 point
Idea: cast a belt from clear silicone/polyurethane with embedded magnets. Wrap it around a stack consisting of the screen and a PCB with printed coils (a PCB motor). Making it slide smoothly over all the internal surfaces might be an issue. Bearings + PTFE, perhaps?
If the coils aren't enough for position sensing, you could add hall-effect sensors. You could use a pair of simple hall switches, mounted such that you get a quadrature output as the magnets go by (one lined up with a magnet, the other half way between two magnets). This might be a good idea, anyway, as brushless motors are easier to control at low speeds with feedback.
kelvinA wrote 02/01/2023 at 21:14 point
I ran a mental simulation using the assumption of 1x1x1mm magnetic cubes of alternating polarity orientation cast into a 1.5x1.5mm (square cross section) silicone belt.
The proposed solution... failed, due to:
- PCB motor unlikely to generate 240g of opposing force
- Silicone likely to absorb haptic vibrations
- Friction of silicone against screen surface
- Additional circuitry needed for hall effect sensors, providing less resolution than what [magnetoresistive sensor -> 24-bit ADC] can provide
- Hall effect sensors do not offer absolute encoding of rotor position
RunnerPack wrote 02/02/2023 at 15:36 point
- Since you wouldn't want to obscure the screen, I was thinking two rings of magnets; one on each rim of the belt, rather than a single ring. This would double the force metric in your mental simulation. To double it again, a second PCB on the underside of the belt could be used (i.e. belt, screen, PCB, belt, PCB).
- I disagree with your vibration damping theory; both silicones and urethanes come in a range of hardnesses. If nothing suitable can be found, perhaps the magnets could be linked using e.g. nylon belts, which are then over-molded with the silicone/PU.
- The friction of the belt is still an issue, but I don't think it's insurmountable.
- I didn't know absolute position sensing was a requirement. I thought this was essentially a flat scroll-wheel with a screen inside (and, in any case, I question the utility of having a screen under your fingers on a chording keyer).
kelvinA wrote 02/02/2023 at 21:57 point
- The screen is not a fundamental requirement and more of an aesthetic Quality Of Life feature. It's easy for a maker to omit the screen in favour of another flat material, but difficult to go the other way around. For this application, think of it more as a thin, uniformally lit RGB led backlight in the exact size I need that just happens to be able to show visual animations instead of block colours.
- I was simulating a belt that's flexible enough to take a 5mm radius pulley turn. You haven't mentioned the use of voice coils or a vibration motor, so I simulated the haptic events originating from the main motor.
- UWMPE tape is the best candidate I know of for friction reduction. It wasn't mentioned so I didn't simulate it.
- Absolute encoding is used for BLDC current control and analog alternate modes for Tetent. Ideally, it could also be used to mitigate natural cogging in the motor with software.
