Latest and greatest
12/15/2023 at 13:36 • 0 commentsI received the new prototypes of the ESP-CM3 and the programmer and everything works perfectly fine!
If you can see it... look very close... what does the ESP say?
exactly.. it is an ESP32-S3 Version!! woop woop - turned out that ESP32-S2 and S3 are somewhat footprint compatible!
Openthing 1 ESP-CM3 Programmer Incoming!
06/23/2023 at 11:36 • 0 commentsHey! Remember that epic 3D image I showed you a while back? Well, guess what? I finally got my hands on the real deal! I ordered the components and the PCB of this awesome Openthing 1 ESP-CM3 Programmer Board, and it arrived yesterday. It's the key to unlocking some serious programming power. I wasted no time and started soldering all the components onto the PCB.
Then came the big moment. I plugged it in, turned it on, and bam! ... NOTHING happened! of course I forgot to turn on the USB Port!
I turned it on and bam! ... one Green LED and some magic smoke appeared! :D
I turned it off and started checking (again) - turned out 3V3 and GND was shorted but the magic smoke came from one of the expensive components which I only ordered 2 of, the CP2102N USB to UART Chip. So I replaced it - checked everything for more shortages. Turned it on again and bam!... IT WORKED!
It got recognized by the USB! Then I throwed in the ESP-CM3 and bam! ... NOTHING HAPPENS haha.
After some investigation it turned out I messed up Tx and Rx from the ESP-CM3 SO-DIMM Connector to the CP2102N which actually have to be swapped on the way. So I patched it and bam! ... everything worked... maybe... except for the Rx and Tx LEDs!
More debugging! "yay"
This time it was the CP2102N Chip which actually needs programming to enable the TXT and RXT Pins! So I downloaded this MASSIVE 1.6GB Software-suit to simply enable this Pins.. and bam!
Finally everything worked as expected and I am very happy about it!
If you read this - please write +1 as a comment :)
A little something...
04/13/2023 at 10:56 • 0 commentsI made a little something and ordered the PCB already...
10 Prototypes
03/21/2023 at 15:41 • 0 commentsThanks PCBWay for sponsoring, producing and sending me 10x Prototypes of the ESP32-CM3! They look delicious and I can send them out now to anyone interested in working with it and give me feedback FOR FREE!
The PreLaunch page for CrowdSupply is ready!!
03/15/2023 at 07:55 • 0 commentsThe PreLaunch page for my CrowdSupply Project is ready!!
Feel free to check it out and subscribe to get notified once it is launched!
https://www.crowdsupply.com/open-things/openthing-1-esp-cm3
I would love to see this being shared as well so I can reach my goals!
