A 4$, 4ICs, Z80 homemade computer on breadboard
No iron, no cry! Build a mini 4MHz Z80 64kB RAM system with Basic and Forth interpreters, CP/M 2.2, QP/M 2.71, Assembler and C toolchains
This is the Z80-MBC (Mobile Breadboard Computer), a mini 4MHz Z80 64kB RAM system with Basic and Forth interpreters, CP/M 2.2, QP/M 2.71, Assembler and C toolchains.
It is a complete development "ecosystem", and using the iLoad boot mode it is possible cross-compile, load and execute on the target an Assembler or C program with a single command (like in the Arduino IDE).
More, it can be easily expanded and it has an "Arduino heart" using an Atmega32A as an "universal" I/O emulator, and can be used and powered with a tablet or smartphone too...
This project has grown a lot on the way (more than I've supposed at the beginning...) and now is renamed as "Multi Boot Computer" and is available on PCB (thanks to Bill Westfield) too.
* * NOTE * * : The new Z80-MBC2 is out!. Check it here: ( https://hackaday.io/project/159973 )
During some surfing on Ebay I realized that with 4$ it is possible to buy enough ICs to build a complete Z80 system that can be done using a breadboard, and taste some flavor of retro computing.... So I did it and here it is the story!
Here is a video with the Z80-MBC in action:
and here with a smartphone (so it is explained the word "Mobile" in his name...) with a common OTG cable (the various test clips in this video were used for some measurements with a Logic Analyzer):
* * HARDWARE OVERVIEW * *
The needed ICs are:
  • Z80 CPU CMOS (Z84C00) 4Mhz or greater ($1.16)
  • Atmega32A ($1.70)
  • TC551001-70 (128kB RAM) ($1.10)
  • 74HC00 ($0.25)
Total cost: $4.21
The wires were taken from salvaged broken LAN cables, and the other components were salvaged from others unused breadboards.
The schematic is attached in the Files section. The MCU Atmega32A is used as universal I/O subsystem, as Eeprom, and as reset and 4MHz clock generator for the Z80 CPU.
Into the Atmega32A it is flashed an Arduino bootloader taken from here , and it is possible to use the Board Manager of the Arduino IDE for that.
Flash the Arduino bootloader at first (with the method you prefer), next you can start to build the whole thing!
Of course I used the Arduino IDE to develop the IOS (I/O Subsytem) that interacts with the Z80 bus and "virtualizes" the peripherals seen by the Z80 CPU.
As oscillator it is used the internal 8MHz Atmega32A oscillator, so no quartz is needed, and from this one is derived the 4MHz clock for the Z80 CPU (so the "Internal 8MHZ osc." bootloader variant must be chosen when flashing the bootloader from the Arduino IDE!).
The 74HC00 is mainly used as RS flipflop to stop the Z80 CPU during I/O operation, giving the needed time to the Atmega32A to interact with the Z80 bus.
The 128kB RAM TC551001 is used only for half (64kB) because the Z80 address space is only 64kB (I've chosen this IC for the low cost).
Note that only the CMOS version of the Z80 CPU can be used here. This because only CMOS version, under given condition that are respected in this schematic, has logical levels compatibles with Atmega32A and 74HC00.
NOTES ABOUT THE COMPONENTS:
You can use any Z80 CMOS speed grade, because the lowest is 4MHz.
The 74HC00 can be substituted with a 74HCT00 if you already have one.
The RAM chip TC551001-70 can be substituted with any suitable 64kB RAM (do not use < 64kB RAM).
The USER led (D5 in the schematic) MUST be blue or white just to be sure that V(forward) is >= 3V.
Here is a video that shows a simple basic program that interacts with the "USER led" and "USER key":
On the breadboard there are others status led: the HALT led turns on if an HALT instruction is been executed and the Z80 CPU is in a Halt state, the DMA led turns on during DMA operations when the Z80 bus is in Hi-Z, the IO_OP led turns on when the Z80 CPU is accessing a I/O virtual device "emulated" by the Atmega32A (as the serial port), the LED_D0 led is the classical "Arduino" led (that one connected to D13 pin on the Arduino Uno) that here is connected with the Arduino D0 pin and is turned on normally as a power on indicator.
The serial port SERIAL-USB (see schematic)...
S221116_R050720_Z80.ino
Adds support for 4 drives and others updates. Please see the following repo (created by Al Williams) for new tools, updates and info: https://github.com/wd5gnr/Z80-MBC (by Al Williams)
ino - 165.09 kB - 07/07/2020 at 13:13
Download
S111216.c
TASM Assembler utility.
C Source File - 1.21 kB - 05/15/2018 at 06:05
Download
build.sh
Linux shell script to invoke TASM for WINDOWS (using wine) to assemble Z80 source code and produce a HEX file and a 'C' header file containing the code. Requires TASM 3.2 and wine. See the notes in the script (by Scott).
x-shellscript - 1020.00 bytes - 05/14/2018 at 19:31
Download
optiboot_m32-20mhz.hex
Anyone wishing to overclock the AVR at 20MHz; OptiBoot HEX file for ATmega32/A running at 20MHz (by Scott).
x-hex - 1.31 kB - 05/14/2018 at 18:29
Download
optiboot_m32-8mhz.hex
OptiBoot HEX file for ATmega32/A running at 8MHz (by Scott).
x-hex - 1.31 kB - 05/14/2018 at 18:28
Download
View all 39 files
  • 1 × For the breadboard version see the file "Z80-MBC - BOM.xls" in the Files section
  • 2 × For the PCB version see the file "Z80-MBC PCB version - BOM.xls" in the Files section
  • The Z80-MBC2 is out!
    Just4Fun07/25/2018 at 16:25 0 comments
  • Hardware Fix for the A041116 schematic (USER led and key)
    Just4Fun07/19/2018 at 18:09 0 comments
    During some tests on the new Z80-MBC2 I realized that the circuitry of the USER led and key (that is the same used in the Z80-MBC) could cause in some cases an erratic behavior of the USER key (USER key not recognized when pressed).
    The solution is easy, and the fix requires only to change the values of R14 and R15 (see the A041116 schematic) to 390 Ohm (both) as shown:
    Remember that the USER led (D5) must have a forward voltage drop (Vf) of at least 2.7V (e.g. a blue led).
    Please note that this fix is suggested only if you are building a new board or if you are experiencing difficulties with the USER key.
    If you already have a perfect working board there is absolutely no need to apply this fix.
  • Bug fix: the "ghost RTC"
    Just4Fun02/10/2018 at 17:01 0 comments
    Reading this Japanese article on a kit sold in Japan to build a Z80-MCB, I realized the presence of a possible bug seeing this two images:
    As you can see, there is a Z80-MCB without any Virtual Disk or RTC attached and in the resulting screenshot the RTC appears present.
    After a quick check I found a little bug in the RTC discovery routine that see a "ghost RTC" when the Virtual Disk is not present.
    So I've uploaded a new "sketch" (S221116_R100218_Z80.ino) that fix the bug.
    Note that if you have the Virtual Disk already installed, there isn't any real need to upgrade.
  • How to make custom Virtual Disk images
    Just4Fun05/29/2017 at 14:29 1 comment
    To do that you need two really powerful tools: Cpmtools to create CP/M disk images and SRecord to manipulate ROM/EPROM images.
    Take in account that the structures of the virtual disk 0 and 1 of the Z80-MBC are different. Disk 0 has the two first tracks reserved for the system image (loaded into RAM by the CP/M loader), instead disk 1 doesn't have this "reservation". This means that the images have a different "structure". More, because disk 0 must have the system image inside the two first tracks, the disk 0 image creation will be different if the OS is CP/M rather than QP/M.
    So to make things easier I've prepared some batch file to simplify the needed operations.
    As for the Assembler and C toolchains you need a Windows host or VM.
    Here all the steps to set up the needed tools:
    1. Create a working directory on your Windows Machine;
    2. Download Cpmtools and unzip in your working directory;
    3. Download last version of SRecord and unzip in your working directory;
    4. Download from the Files section CPMtools-custom.zip and unzip the files into the directory containing the Cpmtool executables (as cpmcp.exe). During the copy overwrite the file DISKDEFS because the new one contains the needed definitions for the Z80-MBC;
    5. Download from the Files section SRecord-custom.zip and unzip the files into the directory containing the SRecord executables (as srec_cat.exe).
    Now you are ready to create your custom image. First create a sub-directory (called e.g. CPM-files) in the cpmtools directory to store all the files to load in the disk image. Check that they fit into the 128kB avaliable space.
    Steps to create a Disk 1 image
    1. Go to the cpmtools directory and with an editor modify/add/delete in the file MakeDisk1.bat the various lines "cpmcp -f z80mbc-d1 %dskfile% CPM-files\xxxxx.yyy 0:xxxxx.yyy" to match the directory in your host (if needed) and all the files to load (xxxxx.yyy);
    2. From the cpmtools directory open the provided DOS command shell and give the following command (I'll use here the name disk1.dsk for the disk image file):
      MAKEDISK1 disk1.dsk
    3. After the execution copy the file disk1.dsk in the SRecord directory;
    4. Go to the SRecord directory, open the provided DOS command shell and give the following command:
      D1TOHEX disk1.dsk
    5. After the execution you will find four files named from disk1_SEG0.hex to disk1_SEG4.hex to upload into the virtual disk with iDisk.
    Steps to create a Disk 0 CP/M image
    1. Go to the cpmtools directory and with an editor modify/add/delete in the file MakeDisk0CPM.bat the various lines "cpmcp -f z80mbc-d0 %dskfile% CPM-files\xxxxx.yyy 0:xxxxx.yyy" to match the directory in your host (if needed) and all the files to load (xxxxx.yyy);
    2. From the cpmtools directory open the provided DOS command shell and give the following command (I'll use here the name disk0CPM.dsk for the disk image file):
      MAKEDISK0CPM disk0CPM.dsk
    3. After the execution copy the file disk0CPM.dsk in the SRecord directory;
      D0TOHEXCPM disk0CPM.dsk
    5. After the execution you will find four files named from disk0CPM_SEG0.hex to disk0CPM_SEG4.hex to upload into the virtual disk with iDisk.
    Steps to create a Disk 0 QP/M image
    1. Go to the cpmtools directory and with an editor modify/add/delete in the file MakeDisk0QPM.bat the various lines "cpmcp -f z80mbc-d0 %dskfile% CPM-files\xxxxx.yyy 0:xxxxx.yyy" to match the directory in your host (if needed) and all the files to load (xxxxx.yyy);
    2. From the cpmtools directory open the provided DOS command shell and give the following command (I'll use here the name disk0QPM.dsk for the disk image file):
      MAKEDISK0QPM disk0QPM.dsk
    3. After the execution copy the file disk0QPM.dsk in the SRecord directory;
      D0TOHEXQPM disk0QPM.dsk
    5. After the execution you will find four files named from disk0QPM_SEG0.hex to disk0QPM_SEG4.hex to upload into the virtual disk with iDisk.
    Remember that you...
  • A new OS: QP/M 2.71 and a RTC for timestamping
    Just4Fun05/23/2017 at 15:37 0 comments
    Here is an interesting alternative to CP/M developed by MICROCode Consulting that supports also file timestamping, and it is 100% CP/M 2.2 "compatible".
    MICROCode Consulting has released the original installation files and all the documentation in their site with the "restricted usage" condition, that means free for non-commercial use and for personal use only, so it should be ok for us. Anyway I've sent them a mail about this project.
    To enable timestamping you need a DS3231 based RTC module like this one:
    WARNING: these modules can cause battery "explosion"! How to fix it
    This cheap modules have a trickle charging circuit that may cause the "explosion" of the battery if you use a standard CR2032 cell. More, it can damage also a rechargeable LIR2032 cell (see this thread). So the safer thing is "disable" the trickle charging circuit (a CR2032 can last 5/10 years, so there is no practical need to a rechargeable battery, after all...).
    To avoid any charging current flowing into the battery you can take away the series limiting 200 Ohm resistor (or cut the trace). Alternatively you can take away the red diode, or destroy it (it is in series with the 200 Ohm resistor). In the following photo you can see the module with some Kapton tape (used as thermal barrier) before to desolder the 200 Ohm resistor (on the right marked as 201) with an hot air gun:
    And here after the desoldering:
    Now the module it's safe and a CR2032 can be used. To connect it use the SCL/SDA/VCC/GND terminals and connect them at the corresponding pins of the IOEXP/I2C connector of the Z80-MBC (pay attention because the position of the signals is different):
    QP/M quick set up guide
    The setup is quite similar to those used to install CP/M. The Assembler automated toolchain must be already set up and the Virtual Disk Module present.
    Here all the steps:
    1. Connect the DS3231 module (with the CR2032 battery inside);
    2. Update the IOS using the new file S221116_R100218_Z80.ino in the File section;
    3. Reboot the Z80-MBC and from a terminal emulator you'll see this:
      Press Y. If you are enough fast you have the RTC set up with the right date/time taken from the sketch compile time (if you are lazy like me you'll find this very handy...). In any case it is possible adjust the date/time manually too from the boot selection menu;
    4. Reboot the Z80-MBC again and select the iLoad boot mode;
    5. From the File section download the file "QPM271_DiskPack.zip", unzip it in the directory used for the Assembler automated toolchain;
    6. Upload the file "iDisk - S250317.hex" to the Z80-MBC using the Dos batch L.BAT (see Assembler automated toolchain) with the command:
      L "iDisk - S250317.hex"
    7. When iDisk waits for the input stream, from the Tera Term menu select "File" -> "Send file..." and choice one of the unzipped .hex file from QPM271_DiskPack.zip;
    8. Repeat step 7 for all the four files;
    9. Press the Reset button on the Z80-MBC and enter into the boot selection menu and select 4 to load the OS from disk 0 (and select the disk light ON if not already done, to have an idea of the behavior):
    NOTE: as already noticed, if you experience errors during the serial upload increase the delay after each line from the Tera Term menu (Setup -> Serial port -> Transmit delay -> msec/line). In my VM I set up a 90ms delay. This is due because Arduino serial port doesn't have any handshaking.
    Now you have QP/M 2.71 up and running, but you need further operations to enable the file timestampig (as stated in the QP/M Installation Guide):
    1. To enable file disk timestamping it is necessary run the utility QSTAMPX from A:
      and do the "disk timestamping" for both A: and B: disks.
      When done type the command D $T and check that the output is similar to this:
    2. Now to set up a starting date to all files give the command QSUB SETDATE to run a simple batch that I made to do this initialization easily;
    3. Copy the file SETDATE.QSB to drive B: (using the command QPIP B:=SETDATE.QSB) and repeat from B: the same batch (QSUB SETDATE)....
  • AUTOEXEC for CP/M
    Just4Fun05/02/2017 at 16:39 1 comment
    Playing with the Z80-MBC I realized that there was a missing feature: to run a program automatically after the "cold" boot.
    So after some searches I found a way to implement in the BIOS a function similar to AUTOEXEC.BAT for DOS using the CP/M SUBMIT command and a batch file that I called AUTOEXEC.SUB (of course...).
    Editing the AUTOEXEC.SUB file it is possible to run a sequence of commands after the cold boot (as with AUTOEXEC.BAT for DOS), and it is possible enable or disable the execution of the AUTOEXEC batch file from the IOS boot selection menu (but this isn't possible with DOS...).
    AUTOEXEC for CP/M quick set up guide
    You must have CP/M 2.2 already up and running (see CP/M 2.2, iDisk and a new IOS), and you can have also only a "single disk" installed (but I recommend the original dual disk configuration), meaning that only U1 (see the A110417 schematic) is populated. Of course the Assembler automated toolchain must be already set up.
    Here all the steps:
    1. Update the IOS using the new file S221116_R300417_Z80.ino in the File section;
    2. Reboot the Z80-MBC and select the iLoad boot mode;
    3. From the File section download the file CPM22SYS_BIOS_S050217_R300417.hex. This file contains only the new CP/M system image for the system tracks of Disk 0, so the "user files" will be left untouched;
    4. Upload the file "iDisk - S250317.hex" to the Z80-MBC using the Dos batch L.BAT (see CP/M 2.2, iDisk and a new IOS) with the command:
    5. When iDisk waits for the input stream:from the Tera Term menu select "File" -> "Send file..." and choice CPM22SYS_BIOS_S050217_R300417.hex. After the upload iDisk will show a summary, at this point press W to proceed and confirm your choice (as done for the CP/M 2.2 installation described in CP/M 2.2, iDisk and a new IOS). Wait until the write and verify phase is completed.
    6. Press the Reset button on the Z80-MBC and enter into the boot selection menu and select 4 for CP/M loader.
    All done!
    How use it
    To create or edit AUTOEXEC.SUB from drive A, you can use the ED command or an other editor like the Turbo Pascal editor. In this case remember to terminate the file with a CR, or "strange" things will occur when executing the SUBMIT AUTOEXEC command.
    You can test the execution giving the command SUBMIT AUTOEXEC from drive A (you can omit the extension .SUB inside the SUBMIT command).
    To enable the AUTOEXEC execution after the cold boot change the corresponding state to ON from the usual IOS boot selection menu.
    If the AUTOEXEC is enabled but the AUTOEXEC.SUB file doesn't exist in the drive A, an error will be displayed:
    New "disk packs"
    I've updated both "disk packs" in the files CPM22_DualDiskPack_v2.zip and CPM22_SingleDiskPack_v2.zip with the new BIOS in the system tracks. So if you are installing them for the first time or you need for any reason to reload them, the new BIOS will be installed. I've added an example of AUTOEXEC.SUB too.
    How it works
    The "trick" used was to inject the string "SUBMIT AUTOEXEC" into the CCP (the Command Processor of CP/M) input buffer. The BIOS after the cold boot checks if the AUTOEXEC flag is set in the IOS, and in this case makes the injection. When the CCP starts after the cold boot, it runs this injected command.
    In this video there is an in depth explanation for a "legacy" Altair 8800 clone.
    The CP/M 2.2 and the new BIOS sources are in the file "CPM22 BIOS - S050217 R300417.zip" in the File section.
  • CP/M 2.2, iDisk and a new IOS
    Just4Fun04/20/2017 at 20:36 14 comments
    CP/M 2.2 quick set up guide
    The set up is very simple. I've done an utility (iDisk) to simplify all the needed operations. Of course the Virtual Disk Module must be present, but you can have also only a "single disk" installed (but I recommend the original dual disk configuration), meaning that only U1 (see the A110417.pdf schematic) is populated.
    The Assembler automated toolchain must be already set up.
    Here all the steps:
    1. Update the IOS using the new file S221116_R130417_Z80.ino (or a newer version if present) in the File section;
    2. Reboot the Z80-MBC and select the iLoad boot mode (if not already selected);
    3. From the File section download the file "iDisk - S250317.hex" and copy it into your PC in the directory used for the Assembler automated toolchain . (Do not use the source file "iDisk - S250317.c" because it requires a special compiling option);
    4. From the File section download the file "CPM22_DualDiskPack.zip" and unzip it (for a single disk configuration download the file "CPM22_SingleDiskPack.zip"). Each disk image is divided into four .hex files called "segment" (32kB each) that are named accordingly (e.g. D0XXX_SEG1.hex means the segment 1 of disk 0);
    5. Upload the file "iDisk - S250317.hex" to the Z80-MBC using the Dos batch L.BAT (see Assembler automated toolchain) with the command:
    6. When iDisk waits for the input stream:
      from the Tera Term menu select "File" -> "Send file..." and choice one of the unzipped .hex file from CPM22_DualDiskPack.zip (or CPM22_SingleDiskPack.zip for a single disk configuration). After the upload iDisk will show a summary:
      at this point press W to proceed and confirm your choice.
      You don't have to follow any order in the "segments" upload sequence, iDisk will know how to do. To know before each upload what "segments" have been already written into the disks just see the "Disk segment write status":
      in the photo the segments 0, 1 and 3 of Disk 1 have been already successfully written, so you can choose any of the remaining;
    7. Repeat step 6 for all the eight (or four for the single disk pack) "segment" files;
    8. Press the Reset button on the Z80-MBC and enter into the boot selection menu:
      select 4 for the CP/M loader (and select the disk light ON if not already done, to have an idea of the behavior).
    All done!
    NOTE: if you experience errors during the serial upload increase the delay after each line from the Tera Term menu (Setup -> Serial port -> Transmit delay -> msec/line). In my VM I set up a 90ms delay. This is due because Arduino serial port doesn't have any handshaking.
    Disk speed
    The Virtual Disk Module is based on simple EEPROMs using a 200KHz I2C serial bus. Of course do not expect the same speed of an hard disk with a DMA controller!
    The speed probably is like using the floppy drive of those days...
    Single disk configuration
    You can have also only a "single disk" installed (but I recommend the original dual disk configuration), meaning that only U1 (see the A110417.pdf schematic) is populated.
    In this case you have about 120kB free, because the first two tracks of Disk 0 are reserved for the system image (Disk 1 doesn't have the system image, so all the 32 tracks are used for the file system).
    Because the BIOS is the same and is configured for a dual disk system, if you try to select the "B:" drive you'll get a "BAD SECTOR" error.
    Disk pack contents
    In the disk 0 image there are the various external CP/M commands, the Basic interpreter, the CP/M Assembler and the Macro Assembler.
    I've added also D, an alternative DIR command, and PEG, a bin to hex converter (and vice-versa) to exchange files:
    In the disk 1 image there is the complete Turbo Pascal compiler v3.01A with a sample program (SA.PAS):
    In the "single disk pack" the CP/M Assembler and the Macro Assembler are missing, and the Turbo Pascal is without the installing executable (not a big issue anyway) and without the sample program.
    In a next Log I'll explain how create custom...
  • Virtual Disk Module, a new IOS and ViDiT
    Just4Fun04/13/2017 at 19:37 3 comments
    It's time for a new "module", the Virtual Disk Module! In the photo is that one on the right, near the previous GPIO module.
    In the File section is possible see the simple schematic A110417.pdf with two I2C EEPROM 24LC1025.
    With this module it is possible to emulate two disks of 128kB each (probably like the floppy disk drives of those years).
    Each disk is divided into 32 tracks of 32 sectors. Each sector is 128 bytes long.
    Of course to manage this new HW there is a new release of IOS. The new file S221116_R180217_Z80.ino is in the File section.
    This new IOS checks if the module is present and prints a message if found:
    There is also a new item in the boot selection menu if the virtual disk is found, to use the User led as a disk activity led:
    I suggest to activate this option to have an idea of the behavior.
    ViDiT
    In the File section I've added a simple test program (file "ViDiT - S090417.c") to check the virtual disk. Of course you need to compile it with the C "toolchain":
    About I2C speed
    With this IOS the I2C speed is 200KHz. Note that if you are using a 16MHz external quartz to clock the Atmega32 the I2C speed will be 400kHz. In this case I suggest to lower the two 4k7 pull-up resistors (on SDA and SCL signals) to about 2k2.
    The next Log will bring the CP/M 2.2 up and running...
  • Forth language, new multi-boot selection and a new name
    Just4Fun02/17/2017 at 21:33 4 comments
    Forth
    Thanks to Bill Westfield now we have a new language for the Z80-MBC, the fig-FORTH v1.3 (here the link to the Bill GitHub repository with the source he adapted for the TASM assembler with the needed modifications for the Z80-MBC).
    The acronym "fig" stands for "Forth Interest Group", that was a world-wide non-profit organization (now dissolved) for the promotion of the Forth computer language.
    I've just started to play with this thing, and I must say that it is not the most friendly language I've seen... anyway it is an interesting different approach.
    To enable Forth just upload the new IOS release S221116_R120217_Z80.ino in the Files section, and select the Forth language from the new multi-boot menu (see next paragraph).
    Here it is a "blink" demo program:
    ( Blink test - Forth - Z80-MBC
    : ledon 1 0 P! ;
    : ledoff 0 0 P! ;
    : delay 4000 0 DO NOOP LOOP ;
    : blink CR ." Blinking..." CR BEGIN ledon delay ledoff delay 0 UNTIL ;
    To execute give the command "blink":
    If you are using Tera Term to send a text file to load a forth source, remember to set up a delay of 1ms for each character (serial port managed by the Arduino bootlader doesn't have any handshaking, so for now this is required to handle the serial stream without errors when sending a text file using a terminal emulator):
    New multi-boot selection
    Now pressing the User key after a reset brings to a new menu to chose the preferred boot mode. During this phase the LED-D0 will blink until you choose the boot mode:
    New name
    As you can see from the previous photos, from this release the MBC acronym changes to "Multi Boot Computer"...
  • An automated C language toolchain
    Just4Fun02/09/2017 at 21:26 0 comments
    Here how set up a toolchain to program the Z80-MBC using the C language. It is based on SDCC (Small Device C Compiler) and uses the same "process" of the previous Assembler toolchain.
    In the following it is assumed the the Assembler toolchain is already set up in a Windows host as described in in the Log: New iLoad boot mode and an automated Assembler toolchain.
    So only the SDCC relevant part is explained here.
    Here it is a short video with the toolchain in action:
    What you need to do:
    1. Create a working directory (or use the previous one) where to store the C sources and the two batch files (C.BAT and L.BAT) in the C_batch.zip file from the File section (if you are using the same assembler working directory overwrite the previous L.BAT);
    2. With a text editor search the line:
      "C:\Program Files\teraterm\ttermpro.exe" /c=3 /BAUD=9600 /w="Z80-MBC Terminal" /m=LoadZ80.ttl
      inside C.BAT and L.BAT and verify that both the path and the COM number (/c=3 means COM3) meet your system;
    3. Download and install SDDC from here;
    4. Download the file S030217_crt0.s from the Files section in the working directory;
    5. Open the DOS command line and give the command: "sdasz80 -o S030217_crt0.s".
      Then rename the generated S030217_crt0.rel as crt0.rel. Copy it in the SDCC directory "C:\Program Files\SDCC\lib\z80" (may be a bit different in your system) overwriting the old one.
    All done!
    As usual close Tera Term before every new upload.
    To check if it is all ok, download from the File section the file C_demo.zip and unzip it in the working directory.
    From the DOS command line give the command: "C Blink.c" to check if all the toolchain works as in the video.
    Try also the other demo ANSItest.c (taken from here) to check the ANSI capabilities of a different terminal emulator or a physical terminal:
    About SDCC
    I'm pretty new to SDCC. The SDCC documentation is 8051 "focused", so the given examples can be misleading if used with an other processor in mind.
    When "porting" SDCC to a target HW, there are 3 things to prepare:
    • customize the crt0.rel file that contains the initialization code for the target system;
    • add to the library the function putchar(char c) to send output to the console;
    • add to the library the function getchar() to read from the keyboard.
    I found the documentation quite missing about how to modify for a custom system.
    In particular in the provided crt0.s example there isn't a needed global declaration of three variables (l__INITIALIZER, s__INITIALIZED and s__INITIALIZER). Without this declaration the code will not compile.
    And to make this customization you need to know how the provided assembler works, but the assembler manual is not provided. So you must find it googling...
    If you are used to the Arduino IDE, read carefully the SDCC manual. This C compiler is a lot more "rude" about types and syntax... (as C standard is...).
    Last minute update
    Just found the assembler and linker documentation here!
View all 14 project logs
  • 1
    Quick instructions intro:
    All the detailed instructions are provided in the "DETAILS" section and in every "LOG".
    Because this project has grown a lot on the way (more than I've supposed at the beginning...) here you can find a short and simple build guide without "navigate" into all the various "LOGs".
    This short guide is referred to the current (at present date 31 August 2017) last "level" of development as described in "A new OS: QP/M 2.71 and a RTC for timestamping".
  • 2
    Add the Atmega32 support in your Arduino IDE:
    The standard distribution of Arduino IDE doesn't have the Atmega32 "core" support files.
    You need to add them from here.
  • 3
    Flash the Atmega32:
    First of all you need to flash the Arduino bootloader into the Atmega32.
    To do this there are a lot of ways. I use a cheap USBASP programmer that you can find "around" for less than 2$.
    Remember to select from Arduino IDE the "Atmega32 8MHz Internal" clock option before flashing the bootloader!!!
View all 6 instructions
Dutchman wrote 08/28/2017 at 01:52 point
Hi, i have a question about the Z80, i couldn't find your z80 (Z84C004) and could only find the Z84C0020, and from what i understood the only difference between these two is the speed at wich they need to run (your z80 at 4Mhz and mine at 20Mhz), since im quinda of noob could you explain what are the alterations to be made to the board in order for these to work ?
Just4Fun wrote 08/29/2017 at 06:20 point
Hi, you can use the Z84C0020 without any change. The minimum clock frequency for *any* CMOS Z80 is 0Hz (DC)!
WestfW wrote 08/09/2017 at 21:30 point
Can you attach a "license" of some kind to the design and various firmware bits?
I had someone asking about the PCB license (now explicitly CC BY-SA 4.0, unless that's unacceptable to you.)  Various institutions and distribution mechanisms get pretty fussy about having an explicit license that their lawyers can understand.
Just4Fun wrote 08/10/2017 at 06:33 point
Hi, I'm completely a noob about "licensing"... :)
So you mean that is better to add an explicit  disclaimer on "every" schematic and SW source file....?
I've added in the bottom of the "Details" a last "paragraph" about licensing. Do you thing that it is enough?
I've added also a licensing note in my git repository (https://github.com/SuperFabius/Z80-MBC). I've "choose" GPL v3 but I haven't no idea if CC BY-SA 4.0 could be "better".
This things drive me crazy....
Could give me some guidance....?
BTW (after some googling...): in the creative common site they say that the CC license is not appropriate for SW/HW....  (https://creativecommons.org/faq/#Can_I_apply_a_Creative_Commons_license_to_software.3F), but here (https://www.fsf.org/blogs/licensing/cc-by-4-0-and-cc-by-sa-4-0-added-to-our-list-of-free-licenses) they say that are "compatible" with GPL v3...  OMG!!!
An other interesting article about HW: https://forum.kicad.info/t/using-the-l-gpl-as-an-open-source-hardware-license/1925/2
WestfW wrote 08/11/2017 at 07:55 point
Grr.  Long reply deleted by the Hackaday.io software...
Interesting links:
http://www.ladyada.net/library/openhardware/license.html
https://www.oshwa.org/faq/
Personally, I'm not fond of "viral licenses" like GPL that insist that everything that comes near them also become open source, and prefer MIT for software.  Other people think that the viral property is really important.
Hardware seems to be problematic because OSSW licenses are based on copyright, but copyright only protects a particual expression of intellectual property.  In theory, when I re-write your pdf schematic in EAGLE and make a PCB, that's a different enough expression that it wouldn't violate the original copyright.
One thing that I think is particularly important is some sort of "statement of intent" - just write what you want to allow and disallow, in plain english rather than license-eese.  It may not hold up in court, but at least people will have a good idea whether they're intentionally going against your wishes or not.  For example, you can find Arduino statements to the effect that they intend to allow commercial and proprietary products to be based on the Arduino core (and hardware), which is comforting in spite of the fact that some of the licenses they use are pretty ambiguous when it comes to embedded firmware...
Just4Fun wrote 08/11/2017 at 10:57 point
To keep it simple, now there is a "Licensing" paragraph at the end of the main "Description/Details" paragraph, and on the git repository the "LICENSE" file too (as you did in your repository). All GPL v3, that should be compatible with CC BY-SA 4.0.
I've added a "fair" request to mention the author if someone uses this material... :)
I think that now it should be sufficient (isn't it...?).
k8lh wrote 07/27/2017 at 23:27 point
Very nice project.
Can an ATMEGA1284P be used instead of the ATMEGA32A?  If so, are any changes required in the Arduino sketch?
Cheerful regards, Mike
mick wrote 07/28/2017 at 19:13 point
They look very similar to me, apart from the increased memory spaces on the 1284P. Pinouts & operating voltages seem to be the same.  I should think that it would be ok. The Mightycore boot loader supports that chip too. If you've already got one it would definitely be worth a try.
Just4Fun wrote 07/29/2017 at 19:54 point
Hi, yes it is  possible.
An other user (Steve) has successfully used an Atmega644 that it is quite similar to yours (search among the comments). He changed the clock activation code. This is necessary because Atmega644/1284 have some differences in some register naming.
Here the modification he did:
// Initialize CLK @ 4MHz. Z80 clock_freq = (Atmega_clock) / (OCR2 + 1) = (Atmega_clock) / 2
  ASSR &= ~(1 << AS2);
  TCCR2B |= (1 << CS20);
  TCCR2B &= ~((1 << CS21) | (1 << CS22));
  TCCR2A |= (1 << WGM21);
  TCCR2A &= ~(1 << WGM20);
  TCCR2A |= (1 <<  COM2A0);
  TCCR2A &= ~(1 << COM2A1);
  OCR2A = 0;   pinMode(CLK, OUTPUT);
May be that this works in yours case too without others variatons
Let me know...
mick wrote 07/25/2017 at 18:30 point
I think it's one of those things - people find time to play with it when they can. :) That's my position at the moment. Too much stuff all happening at the same time. However, I've also been doing a bit of work on porting Nas-Sys 3 over to make this system look very much like a Nascom 2 running through a tty. Probably not a lot of interest in that (other than for myself!). Is anyone still interested in having somewhere to act as a repository for custom disk images for this project? They aren't very big and I still have quite a bit of spare space on my web site where I could perhaps host them as zip files.
villaromba wrote 07/25/2017 at 14:54 point
Are we at the end of the line on this project or is there more in the pipe-line to come???
Just4Fun wrote 07/26/2017 at 07:22 point
Hi, next items in my "to do" list are an SD card and CP/M 3 with banked RAM. Of course they require an HW/SW update and a lot of time... May be after summer...
Currently I'm playing with an other project (probably I'll publish it here when done)...
villaromba wrote 07/27/2017 at 20:28 point
Awesome!!! I look forward to the Z80 enhancements and 'CPLD Fun Board"!!! But of course enjoy the summer hols first :).
mick wrote 07/03/2017 at 18:57 point
My new baby :) https://www.dropbox.com/s/mbuumplvvw16brc/front.jpg?dl=0
and its backside: https://www.dropbox.com/s/990az27og0slrqz/back.jpg?dl=0
I knew I'd eventually find a use for that wiring pencil...
john wrote 07/03/2017 at 22:46 point
Very nice!
Just4Fun wrote 07/04/2017 at 06:11 point
Neat! I've some wire like yours but never used it...
Dylan Brophy wrote 07/04/2017 at 14:52 point
:-) Z80 computers rule!
Starhawk wrote 07/27/2017 at 22:59 point
What are the chips on that board, if I may ask...?
mick wrote 07/28/2017 at 19:28 point
I mostly used the same chips as the original apart from the RAM chip. I couldn't get that part at a reasonable price, but I could get the 6C1008, which is perfectly fine and pin compatible.
Oh, I also got a faster Z80 as the price difference was very little. My RTC chip is different too.
mick wrote 07/01/2017 at 16:38 point
I've just got this built using a similar layout to the one that John used, on pad board. I've included the I/O expansion, virtual disks & a DS1307 rtc chip (because I already had one) c/w cell holder lifted from an old motherboard. Still a bit of space left. :)  I'm just considering using it to boot a modified Nas-Sys as a machine code monitor. Possibly even with a crude method of saving & loading to "disk".
I'm no expert, but as only A0-A5 are needed for the loader, couldn't that free 3 AVR pins for use as a SPI interface to a SD card "hard disk"?
Just4Fun wrote 07/03/2017 at 13:14 point
Yes, it can be done... (it is one of the items in my long "to do" list...). Of course you must do the needed modifications in the sketch, and add pull-down resistors on the A6-A8 address lines.
Cyril V. wrote 06/23/2017 at 18:09 point
I just finish building this project - Works at the first boot love it :)  (BTW - I did find here is some Basic games: http://www.moorecad.com/classicbasic/index.html).
My goal now is to free some pins on the Atmega32 for some
I/O (VGA/SD...).  After some research, I find this project http://www.shaels.net/uploads/Media/SiteDownloads/Mini80/Mini80b.pdf which use a 74HC165 for the address bus to save 6 pins on the MCU (Propeller).
But the 74HC165 can use access only 8 lines of the address bus vs the 9 lines direct on the Atmega32.
Can I use a 16 bits shift register (with only using 9 lines) like this one  http://users.ece.utexas.edu/~valvano/Datasheets/74F676.pdf and for the code does something like that https://forum.arduino.cc/index.php?topic=50633.0
will work?
(btw - I have couple PCB V2 left than I can sell for $4 + shipping - PM me if interested).
Just4Fun wrote 06/23/2017 at 19:46 point
Great! :)
BTW: if you want try some modifications, take in account that there are parts of the code that are strictly tied to the Z80 bus behavior...
PS: the 9th address line is not currently used... :) (and the 74F676 seems to be parallel in serial out, so no good anyway)
PPS: So the 24LC512 based virtual disk worked....
Cyril V. wrote 06/24/2017 at 01:25 point
Thank you for info. I just order couple 74HC165 I will give it a try.
For the 24LC512, I finally manage to find two 24LC1025 for $6 couple the day after on eBay, so I did not bother with the 24LC512. But you can easily find 24LC512 for under $1.
Just4Fun wrote 06/24/2017 at 07:07 point
Just checked now... the HC165 are parallel in serial out too, so no good!! (always check the datasheet before buy...).
BTW: take in account that address lines are used for the I/O emulation too...
PS: I've looked at the schematic you linked again... it seems to me a bit "convoluted"... the HC165 is used to READ A0-A7 but the propeller chip has 8 pins not used... very strange...
Cyril V. wrote 06/25/2017 at 00:11 point
Here is the the website: http://www.shaels.net/index.php/mini80/mini80-general/119-mini8o-overview.
You completely right. Well live and learn :).
The rest of the propeller ports are used for VGA and keyboard:  http://www.shaels.net/index.php/mini80/documents/120-min80-proto1-io-prts-and-devices
The thing is running @ 3.3V : "The CMOS construction of the Z80 should allow the Z80 to operate at a reduced voltage. Digital CMOS devices generally set there logic voltage levels as a percentage of the power supply voltage and not by absolute voltages. This feature should allow the Z80 to operate at the 3.3 volt
level allowing it to interconnect with the Parallax Propeller chip. At
 3.3 volts the Z80 max CPU clock speed will have to be de-rated."
Just4Fun wrote 06/25/2017 at 13:06 point
Hmmm... the Z80 there is completely out of specs.... No...  this isn't my way... definitely... :)
villaromba wrote 05/27/2017 at 14:11 point
Finally QP/M up & running - thankyou ! Looking forward to seeing how to add more progs BUT Drive A is R/W, with 24k space remaining. Drive B is R/W, with 42k space remaining.
Where's it all going to go !!!! ???
Just4Fun wrote 05/27/2017 at 17:30 point
You should use it as a dual floppy machine of those years... I mean using A: for the system and B: for user programs. Of course loading with iDisk the needed disk image, or following the way used by john.
If you do not need turbo pascal just... delete it... :)
villaromba wrote 06/01/2017 at 20:37 point
Thanks for clear instructions, I need them  :) , ..on how to add  custom images with CP/M Tools. Experimented with B: and it works perfectly with my added programs.
john wrote 05/25/2017 at 12:23 point
I could have sworn I read this in the posts somewhere, but I can't find it now.  Can someone tell me how to transfer files to the drive through the console?  I'm wanting to put Zork on the B: drive.  Will PIP do this?
Just4Fun wrote 05/25/2017 at 14:37 point
For now he only way is convert a file to IntelHex format and send it using the terminal emulation. I think that PIP can be used. See here: http://www.gaby.de/cpm/manuals/archive/cpm22htm/ch1.htm#Section_1.6.4
You can also use PEG to convert inside the target (Z80).
Anyway you have remembered to me that I have to write a "Log" to describe how create custom disk images... For "large" programs/applications this is the way to go...
john wrote 05/25/2017 at 17:34 point
That's where i was headed, but I can't get QPIP to do anything with CON: as the source.  I'm putting CP/M back to try that version of PIP (not sure if it's different).
Edit:
CP/M PIP does seem to work and I can get the file to disk, but because of the bin to hex conversion the file is now too big to fit on the disk.  Looking forward to your next log :)
Just4Fun wrote 05/25/2017 at 17:44 point
Yep, I was  just trying that... It seems looping...
I've tested on an emulator with standard CP/M and I was able to write a text from the console using PIP, giving also CTRL-J after every CR.
john wrote 05/26/2017 at 00:59 point
I went around the world to get there, but I eventually got this to work...  I was able to use Grant Searle's DOWNLOAD. COM code from his CP/M project to get the files over.  If anyone's interested, I had to change the DOWNLOAD2.HEX to relocate 0x4100 to 0x0100 and then recalculate the checksums.  Then I pasted that into ZDE and saved it to the disk.  A quick PEG to convert from Intel HEX to a COM file and then just followed the directions to transfer the Zork files over.  Then I found myself "West of House".    :)
Just4Fun wrote 05/26/2017 at 07:26 point
Great idea!
BTW: I've just ordered "some" HD64180 (=Z180) and MC68008. Starting to think what to do with these... May be next winter mini system... :)
john wrote 05/24/2017 at 15:06 point
Nice work!  Waiting on the RTC module to arrive, but since I had a spare Arduino I tried the "DS1307 Emulator Library"...  Works great!
Z80-MBC (Multi Boot Computer) - A041116
IOS - I/O Subsystem - S221116 R110517
IOS: Found RTC DS3231 Generic Module (24/05/17 11:00:36)
IOS: Found Virtual Disk Module
IOS: Disk light is ON
IOS: AUTOEXEC execution is OFF
IOS: Loading phase 1 boot program...
IOS: Loading phase 1 done.
IOS: Z80 is running from now.
Z80-MBC CP/M 2.2 Cold Loader - S150417
Loading... done
Z80-MBC QP/M 2.71 BIOS - S080517
QP/M 2.71 Copyright 1985 (c) by MICROCode Consulting
A>time
24-May-17       11:00:43
A>
And from MBASIC:
LIST
10 SECONDS = INP(7)
20 SECONDS = INP(8)
30 MINUTES = INP(8)
40 HOURS = INP(8)
50 DAY = INP(8)
60 MONTH = INP(8)
70 YEAR = INP(8)
100 PRINT "THE TIME IS: ";
110 PRINT HOURS; : PRINT ":"; : PRINT MINUTES; : PRINT ":"; : PRINT SECONDS
Ok
RUN
THE TIME IS:  12 : 36 : 18
Ok
Just4Fun wrote 05/24/2017 at 17:05 point
Great! These RTC have the same I2C address and the same structure for the main date/time registers. Instead the "control register" are different and at different location. Anyway it seems that are "compatible" at least in the way I've used it...!
john wrote 05/24/2017 at 17:14 point
Yes - I think the 3231 control register ends up being in the RAM on the 1307, so writes to it have no effect, and the initial read to check if the OSC is running fails, so the time setting routine gets triggered.  I added a write to the 1307 register to change the SQW pin to 1 Hz and it worked on the emulator.  I found a 1307 in my parts bin, so I'll wire that up soon.
villaromba wrote 05/27/2017 at 15:53 point
John, thanks for this  info. Where did you find the INP(x) address data from. The module has a temp sensor on it as well, so is it possible to INP that as well ?
WestfW wrote 05/24/2017 at 05:23 point
Neat!  (Man, I had totally forgotten just how tiny CP/M is...)
Loading... done
Z80-MBC CP/M 2.2 BIOS - S050217 R300417
CP/M 2.2 Copyright 1979 (c) by Digital Research
A>dir
A: ASM      COM : D        COM : DDT      COM : DUMP     COM
A: ED       COM : HELLO    COM : LOAD     COM : MAC      COM
A: MBASIC   COM : PEG      COM : PIP      COM : STAT     COM
A: SUBMIT   COM : XSUB     COM : HELLO    ASM : GPIO     BAS
A: AUTOEXEC SUB : HELLO    PRN : HELLO    HEX
A>mbasic
BASIC-80 Rev. 5.21
[CP/M Version]
Copyright 1977, 78, 79, 80 (C) by Microsoft
Created: 15-Dec-80
34811 Bytes free
Ok
10 print 124
list
10 PRINT 124
Ok
run
 124
Ok
Just4Fun wrote 05/24/2017 at 07:30 point
Now you are ready for QP/M too... :)
WestfW wrote 05/24/2017 at 01:35 point
For the record, a 24xx1025 behaves oddly if you forget to connect A2 to VCC.  Writes to the lower half work fine, but not writes to the second 64k...  (sigh.)
Starhawk wrote 05/23/2017 at 16:49 point
Nifty project! Gotta love the budget, and that you're getting great results with it. But I have a couple questions...
One, what would it take, code-wise, to replace the RAM you used, with a UMC UM61512-series chip? The ones on eBay are very fast, ~15nS (vs. ~70nS for your current RAM)...?
Two, how hard would it be to add a real floppy drive to this? I have real 5.25" floppy drives and disks... the experience is worth the trouble, IMO. (Or would it just be that much easier to use SD cards...? Not the same, by any means, but I do have a 32mb card I could toss in there, if CP/M can see it.)
Three, I have a TL866C programmer. That will suffice for Arduino'ing the ATMEGA32, right...?
Since this computer won't /quite/ fit in my budget (currently $4.96) once shipping costs are factored in (aargh!), I'll probably be ordering parts next month, if I don't lose interest [rolleyes] -- which I do all too frequently.
Just4Fun wrote 05/24/2017 at 07:28 point
Hi,
here the answers:
1. Yes, you can use it without any change. Anyway there isn't any advantage to use a so fast SRAM because the Z80 clock is 4MHz, and a 120ns SRAM is more than adequate...;
2. It can be done but is not so easy. Using a SD is a  lot much simpler. But in any case you need an other MPU (at least with the current HW);
3. I haven't a TL866C so I don't know... But I remember that an other user used it. Search among the various comments...
Starhawk wrote 05/24/2017 at 14:48 point
I'm not so hot with the coding... kinda wish I was... maybe sometime soon, you can figure out how to add SD support? I'd help if I could but TBH I can't.
I'm going to try and build it in early June... I don't have the money now :(
Just4Fun wrote 05/24/2017 at 17:31 point
When I said "a lot more simple" I doesn't mean that it is an "absolute" simple task...
You must implement a I2C-SPI bridge and probably heavily modify the disk emulation of the IOS...
Starhawk wrote 05/24/2017 at 20:30 point
...or just add a second ATMEGA ;) drivers would be the difficulty there, though, really... SD cards are way new stuff compared to CP/M...
Maybe it really /would/ be easier to plunk in an 82077AA-5, PLCC socket and all... after all, at least /partial/ support should be in the OS for that... although, at the time CP/M was prevalent, most floppy drives were actually the now-rare-as-hens'-teeth 8-inch variety, not the more well-known 5.25" or 3.5" formats... so some (probably significant) adaptation would almost certainly be necessary. That, and, well, the datasheet for the 82077AA series of single-chip floppy controllers is dated May '94... well past the expiry date of /any/ copy of CP/M...
Probably there's a challenge there. Dunno. I'm not a programmer. I don't mind helping to test, but I can't contribute code... I know just enough programming to know that it's really not for me. I can't think in code. Sorry.
villaromba wrote 05/24/2017 at 16:59 point
Yes, I use the TL866 to do all my ATMega32 programming for this excellent project. You need to get the 'fuse bits' correct in the Config i.e the SUT0, CKSEL3, CKSEL1, CKSEL0, SPIEN, BOOTSZ1 & 0 boxes all ticked, others unticked.
Starhawk wrote 05/24/2017 at 17:02 point
Thanks, that's very helpful :)
Just4Fun wrote 05/14/2017 at 17:05 point
Stay tuned...
john wrote 05/16/2017 at 13:22 point
Suspense is killing me - do I need to dig up a DS1307?
Just4Fun wrote 05/16/2017 at 13:31 point
-LOL-
No, take a cheap DS3231 based module... :)
PS: do not connect any battery into it or it "may" explode if powered... I'll explain all...
john wrote 05/16/2017 at 21:12 point
That's funny - I saw the QP/M and timestamps on the files but completely missed the 3231 log message!
Just4Fun wrote 05/17/2017 at 06:10 point
WestfW wrote 05/13/2017 at 00:14 point
BTW, did you write any test code for the I2C devices that just runs on the AVR without involving the Z80?  Or do standard arduino sketches work?
Just4Fun wrote 05/14/2017 at 16:49 point
To check I2C I used the standard "I2C scanner" example.
WestfW wrote 05/13/2017 at 00:12 point
Hmmph.  Adding the I2C EEPROM to the prototyping area on the PCB, and discovering that I didn't include any power pads that are convenient to use :-(
Cyril V. wrote 05/04/2017 at 18:18 point
What do you think of using this I2c 1602 screen +  5 buttons for possible I/O (it is driven by a
MCP23017)(ebay clone for $5): https://learn.adafruit.com/rgb-lcd-shield
Just4Fun wrote 05/05/2017 at 07:15 point
Yes you can use it. The Z80-MBC will see only a MCP23017 of course, and it is up to you write a program that it is capable to "drive" what is connected to the GPIOs (see GPIO.BAS as an example).
Because the SDA and SCL pullup resistors are already in the Z80-MBC schematic, you *must* check that there isn't any further pullup resistor on your board. If there is any, you must take it away.
Check that the A0, A1 and A2 address pins of the MCP23017 are all connected to GND (like in the schematic you posted), otherwise the IOS will not see it.
Cyril V. wrote 05/05/2017 at 23:44 point
Just waiting for the parts, I will let you how it goes :)
Just4Fun wrote 05/08/2017 at 09:27 point
Thanks! I'm very curious too... :)
joel076 wrote 05/04/2017 at 16:32 point
Can i use BS62LV1027PCP55 as ram instead?
Just4Fun wrote 05/05/2017 at 07:03 point
I've given a look to the datasheet and it seems ok.
Cyril V. wrote 05/03/2017 at 12:54 point
For the Virtual Disk Module can the two 24LC1025 EEPROM be replaced by a lower memory capacity like the 24LC512 or even the 24LC256 (for emulating the two disks of 128kB)?
john wrote 05/03/2017 at 19:15 point
I think it's a bits/bytes thing.  The 24LC1025 is a 128K x 8 (1024K bit)  device, so each chip can hold a 120KB disk image.
Cyril V. wrote 05/03/2017 at 19:28 point
I can't find cheap 24LC1025/24LC1026 on ebay (more than $20 with shipping for only one chip). Any cheaper alternatives?
john wrote 05/03/2017 at 19:54 point
I picked them up for about $3.50 from Mouser.
Just4Fun wrote 05/04/2017 at 06:41 point
I've given a look to the datasheets. The 24LC256 is a "no-go" because the A15 address bit is missing. The 24LC512 may be... It seems compatible. Of course you need four of them to have an equivalent memory space (or two for a "single disk" system).
Here the the way to use them:
I haven't any 24LC512 so I can't test if it works or not. May be I've forget something... It's only a 2 minutes schematic...
So try it at your risk....
Cyril V. wrote 05/04/2017 at 12:30 point
Great, thank you.
