notes.txt
Gpios choosen to control the Robot.
Amazon Invoke sequence and Robots commands (Alexa)
plain - 777.00 bytes - 04/13/2023 at 10:48
Download
First Draft chassis dimensions.
Portable Network Graphics (PNG) - 6.69 kB - 04/13/2023 at 10:46
Preview
Download
Robot_Webcam.ino
Version of ESP32 WEBCAM, acessing AMAZON, taking picture to rekognizer images and receive Alexa commands and finally sensding using infrared to Arduino mega.
ino - 20.13 kB - 04/13/2023 at 10:45
Download
robot_chassis.ino
Version of ARDUINO MEGA robot controller, now with 8 infrared sensors.
ino - 20.33 kB - 04/13/2023 at 10:35
Download
robot.ino
First and poor version of ARDUINO MEGA robot controller.
ino - 7.11 kB - 04/10/2023 at 15:43
Download
hackday_step_support.stl
3D Support to the step motor to fix on chassis
Standard Tesselated Geometry - 286.80 kB - 04/10/2023 at 13:57
Download
hackaday_converter.stl
This is the 3D STL converter from step motor axis to wheels hole.
Standard Tesselated Geometry - 22.54 kB - 04/10/2023 at 13:42
Download
hackaday.pcbdoc
This is the first PCB version of Shield to the Arduino ATMEGA.
Newer version will be draw in the robot Chassis.
It´s on EasyEda format. easyeda.com
pcbdoc - 780.81 kB - 04/10/2023 at 13:05
Download
SCH_hackday.schdoc_2023-04-10.json
This this the first Schematic version of Shield to the Arduino ATMEGA.
JavaScript Object Notation (JSON) - 66.89 kB - 04/10/2023 at 13:00
Download
hackaday.js
This is the Lambda Javascript example that talks with Amazon Alexa and make communication with AWS IoT, where the ESP32 WEBCAM is connected.
Who call this event ? The AWS IoT when receive a JPG image from ESP32 WEBCAM :)
javascript - 8.93 kB - 04/10/2023 at 12:18
Download
hackaday.py
This is the Lambda Python example que invoke the Amazon Text Rekognizer service.
Works together with AWS IoT core ACT RULES
https://www.youtube.com/watch?v=IkR2g0fJ94o
x-python - 3.68 kB - 04/10/2023 at 12:15
Download
main.rar
This file is the Alexa example of Espressif, using the ESP-ADF libraries, used on Lyra T starter kit. Just compile to Lyra T, no changes from the original.
https://github.com/espressif/esp-adf
Here some discussion about portuguese port
https://github.com/espressif/esp-va-sdk/issues/65
RAR Archive - 4.92 kB - 04/10/2023 at 11:54
Download
