Portable Sound Visualization AR Device
Back to overview
A portable AR device that superimposes an image showing the location of a sound source on an image captured by a camera.
  • 3
    Attach the Microcontroller Board.
    Attach the display to the back of the enclosure using double-sided tape. Thread the cables through the slit into the interior of the enclosure.
    Attach the microcontroller board to the fixation board.
    After attaching the microcontroller board, secure the FPC (Flexible Printed Circuit) of the display to the connector.
  • 4
    Install the Microphone Array Board
    Attach the microphone array board to the front panel. It can be secured with four screws and nuts.
    Connect the microphone array board to the microcontroller. It's a good idea to mark the connectors to ensure the correct orientation.
    The pin configuration for the connection points is as follows, according to the following table.
    MaixBitMic Array
    PIN23MIC_D0
    PIN22 MIC_D1
    PIN21MIC_D2
    PIN20MIC_D3
    PIN19MIC_WS
    PIN18MIC_BCK
    PIN17LED_CK
    PIN15LED_DA
    3V3VIN
    GNDGND
    After connecting the cables, secure the front panel to the enclosure with screws.
  • 5
    Attach the back panel and replace the lens.
    Insert the batteries and attach the back panel.
     Secure the back panel with four screws, similar to the front panel.
    Once the back panel is in place, switch out the camera lens for the wide-angle lens.
    The lens is of the M12 screw type.
    That concludes the process.
  • Discussions
