radio_config_Si4463_HC-12.hThe radio configuration header file generated from the WDS application. Work in progress.h - 32.86 kB - 05/14/2023 at 09:58 |
si4463_revb1_HC-12.xmlXML File for the Silabs WDS application, with the configuration that (almost) matches the settings of the HC-12. Work in progress.XML - Extensible Markup Language - 21.97 kB - 05/14/2023 at 09:58 |
