SDO Milliohm Meter v1
Back to overview
A minimal 4-wire milliohm meter with 4.5 digit display
Cyril Hrubis wrote 07/06/2023 at 13:17 point
Awesome project. I did build it just fine, worked on first power on. As for the temperature drift I build a 12 Ohm resistor from aprox. 22cm of 0.1mm manganine wire (wrapped around piece of leftover PCB) which seems to be stable enough, the output drifts less than 1mV when measuring 1Ohm resistor.
Update: I found thick managine wire around 1Ohm that itself does not drift much and the output drifts less than 0.4mV on full scale measurements, which is +4 on the last digit after a few seconds between the open state and the measuring state.
Kuba Sunderland-Ober wrote 02/10/2024 at 18:21 point
Wow, I didn't expect anyone other than me to actually build this thing. There's a v2 coming that implements the ADC and display as well, using cheap parts, nothing programmable nor exotic. I'll gladly send the PCBs for that your way if you wish, since I can't really use more than one or two, and there's no point in getting less than 5 from PCBWay.
Cyril Hrubis wrote 02/29/2024 at 08:50 point
That would be awesome however depending on where you live sending them may end up more expensive than ordering from PCBWay... (I live in Czech Republic).
