IMG20230727113903.jpgAdding the extra wire cover piece, switches and touch pad to the keyboard panelJPEG Image - 3.69 MB - 07/31/2023 at 19:36 |
IMG20230711091802.jpgCreating the back panel for the 10.1 inch touchscreen.JPEG Image - 4.36 MB - 07/31/2023 at 19:36 |
IMG20230717132120.jpgAttaching the panel supports that accept screws to the Pi panel.JPEG Image - 3.42 MB - 07/31/2023 at 19:36 |
IMG20230725212155.jpgAttaching the legs from the 7 inch touchscreen enclosure to the panel the resides behind the 10.1 inch touchscreen.JPEG Image - 3.01 MB - 07/31/2023 at 19:36 |
IMG20230730133602.jpgInternal view of behind the touchscreensJPEG Image - 3.22 MB - 07/31/2023 at 19:36 |
IMG20230710115240.jpgKeyboard panel cut, edges rounded and keyboard hole cut out.JPEG Image - 2.94 MB - 07/31/2023 at 19:36 |
IMG20230726103453.jpgVelcro placed on GPS mouse.JPEG Image - 3.04 MB - 07/31/2023 at 19:36 |
IMG20230716211520.jpgMaking Pi panel supports that accept screws.JPEG Image - 3.07 MB - 07/31/2023 at 19:36 |
IMG20230725133711.jpgPanel that will go behind the 10.1 inch touchscreen and legs from 7 inch touchscreen enclosureJPEG Image - 3.64 MB - 07/31/2023 at 19:36 |
IMG20230717132901.jpgPanel placed over Pi and Pi mount, screen mount is not obstructed by panel.JPEG Image - 2.98 MB - 07/31/2023 at 19:36 |
IMG20230711102035.jpg10.1 inch touchscreen mounted, wires ran, mount articulated.JPEG Image - 2.94 MB - 07/31/2023 at 19:36 |
IMG20230725104054.jpgPower switch has industrial strength glow powder in the UV resin.JPEG Image - 2.93 MB - 07/31/2023 at 19:36 |
IMG20230720225414.jpgWebcam mounted to Pi panelJPEG Image - 3.16 MB - 07/31/2023 at 19:36 |
IMG20230729204927.jpgKeyboard panel secured with 3d printing penJPEG Image - 2.90 MB - 07/31/2023 at 19:36 |
IMG20230729220804.jpgCustom legs added to the bottom of the Top portion of the case to create balance and help to support the weight.JPEG Image - 2.82 MB - 07/31/2023 at 19:36 |
IMG20230720222316.jpgSlit cut for webcam on Pi panel.JPEG Image - 2.84 MB - 07/31/2023 at 19:36 |
IMG20230711092524.jpgPanel will be placed on back of touchscreen.JPEG Image - 2.82 MB - 07/31/2023 at 19:36 |
IMG20230727151153.jpgSupports placed on the bottom of the keyboard panel.JPEG Image - 2.61 MB - 07/31/2023 at 19:36 |
IMG20230725104109.jpgPower switch glowingJPEG Image - 2.51 MB - 07/31/2023 at 19:36 |
IMG20230728193542.jpgExtra supports fabricated out of plastic panel placed under top of keyboard opening to ensure no weight is placed on the USB plugs.JPEG Image - 2.55 MB - 07/31/2023 at 19:36 |
IMG20230711120521.jpg7 inch screen in screen enclosureJPEG Image - 2.60 MB - 07/31/2023 at 19:36 |
IMG20230711092549.jpgPanel placed on back of 10.1 inch panel.JPEG Image - 2.88 MB - 07/31/2023 at 19:36 |
IMG20230711102055.jpgHow 10.1 inch screen will sit when case is closedJPEG Image - 2.72 MB - 07/31/2023 at 19:36 |
IMG20230719174831.jpgBoth the 10.1 and 7 inch screens are installed, the Pi panel is currently offJPEG Image - 2.70 MB - 07/31/2023 at 19:36 |
IMG20230709133222.jpgPi and Pi case / support placed and 10.1 inch touchscreen mount placed also.JPEG Image - 2.53 MB - 07/31/2023 at 19:35 |
IMG20230725195207.jpgHoles cut for ports on the panel the resides behind the 10.1 inch panel.JPEG Image - 2.52 MB - 07/31/2023 at 19:35 |
IMG20230719174353.jpg7 inch touchscreen mount placed.JPEG Image - 2.72 MB - 07/31/2023 at 19:35 |
IMG20230717130841.jpgPi panel supports that do not accept screws placed.JPEG Image - 2.64 MB - 07/31/2023 at 19:35 |
IMG20230729204931.jpgHardware build complete!JPEG Image - 2.60 MB - 07/31/2023 at 19:35 |
IMG20230720222331.jpgWebcam placed on Pi panelJPEG Image - 2.51 MB - 07/31/2023 at 19:35 |
IMG20230709131419.jpgNano tape strip laid for 10.1 inch touchscreen mountJPEG Image - 2.54 MB - 07/31/2023 at 19:35 |
IMG20230721150656.jpgwebcam ribbon attached to PiJPEG Image - 2.50 MB - 07/31/2023 at 19:35 |
IMG20230722132830.jpgRunning the wired from the PiJPEG Image - 2.53 MB - 07/31/2023 at 19:35 |
IMG20230709123630.jpgScreen fits!JPEG Image - 2.51 MB - 07/31/2023 at 19:35 |
IMG20230712090321.jpgWires ran for 10.1 inch screenJPEG Image - 2.47 MB - 07/31/2023 at 19:35 |
IMG20230717132253.jpgPi panel mountedJPEG Image - 2.39 MB - 07/31/2023 at 19:35 |
IMG20230726121404.jpgRTL-SDR dongle attached to the side of the case with Velcro.JPEG Image - 2.37 MB - 07/31/2023 at 19:35 |
IMG20230723000032.jpg7 port USB hub mounted behind the 7 inch screen.JPEG Image - 2.30 MB - 07/31/2023 at 19:35 |
IMG20230717130959.jpgPi panel cut, bottom edges rounded.JPEG Image - 2.31 MB - 07/31/2023 at 19:35 |
IMG20230720091503.jpgPower block mounted behind the 10.1 inch screen with nano tap.JPEG Image - 2.28 MB - 07/31/2023 at 19:35 |
IMG20230726121856.jpgRTL-SDR dongle mounted above the webcam with Velcro.JPEG Image - 2.17 MB - 07/31/2023 at 19:35 |
IMG20230730095456.jpgWorking with 10.1 inch screen in upright positionJPEG Image - 2.13 MB - 07/31/2023 at 19:35 |
IMG20230726101913.jpgGPS mouse mounted with Velcro.JPEG Image - 2.18 MB - 07/31/2023 at 19:35 |
IMG20230731131616.jpgHigh power magnets mounted to both the 10.1 inch mount arm and inside top of the case to create the force//support needed to keep that screen upright when you want it uprightJPEG Image - 2.09 MB - 07/31/2023 at 19:35 |
IMG20230726123638.jpgSpacer that was cut to try and tighten up the 10.1 inch mount arm, in the end this was thrown out as it was useless and replaced with high power magnets.JPEG Image - 2.06 MB - 07/31/2023 at 19:35 |
IMG20230730214439.jpgblack Vinyl for the magnet so it's not shinyJPEG Image - 1.98 MB - 07/31/2023 at 19:35 |
IMG20230725224731.jpgPanel behind the 10.1 inch touchscreen placed.JPEG Image - 1.98 MB - 07/31/2023 at 19:35 |
IMG20230727145442.jpgSupports for under the keyboard panel.JPEG Image - 1.92 MB - 07/31/2023 at 19:35 |
IMG20230726103932.jpgGPS mouse mounted inside the case with VelcroJPEG Image - 1.87 MB - 07/31/2023 at 19:35 |
IMG20230726123644.jpgWhere the spacer went that failed and was replaced with magnets.JPEG Image - 1.76 MB - 07/31/2023 at 19:35 |
IMG20230717123434.jpgPi panel support that accepts screws completeJPEG Image - 1.67 MB - 07/31/2023 at 19:35 |
IMG20230717123445.jpgPi panel supports that do not accept screws completeJPEG Image - 1.68 MB - 07/31/2023 at 19:35 |
