Walter on the IoT Show from Olivier Bloch
05/01/2024 at 20:29 • 0 comments -
IoT SIM cards available for private persons
04/26/2024 at 21:54 • 0 commentsWe have reached another milestone in our mission to make cellular IoT available to anyone, including private persons. The most heard feedback on the Walter project is about how one can buy a SIM card that actually supports modern NB-IoT or LTE-M connectivity. Especially for private persons these SIM cards were unobtanium if you are not a business.
Together with Soracom we have been working hard on our online order portal. You can order Soracom global SIM cards in single quantity units with excellent roaming agreements and power consumption. Check it out on http://shop.dptechnics.com
Walter is live on Crowd Supply
03/23/2024 at 22:03 • 0 commentsSince publishing our pre-launch page, we’ve been hard at work perfecting both our design and our manufacturing plan. Along with beta testers from all over the world, we’ve been busy monitoring and evaluating Walter’s performance in various applications. We’d love for you to have a look at our project page and join us in the exciting world of cellular IoT by backing the Walter campaign!
The case fits like a glove
12/12/2023 at 16:38 • 0 commentsWe just received the prints after a long wait and are very happy with the results. The case fit's like a glove. Next step is to wait for the threaded inserts to arrive to make it complete.
An open source case is available
11/23/2023 at 14:07 • 0 commentsHi,
I have drawn a very simple, but easy to print, case for Walter. It allows you to easily test Walter as a stand-alone tracker device without exposing the bare board to much. You have space for all antenna's in the housing and there is also a spare hole to install an SMA pigtail if you want to use an external GNSS antenna. All design files are on Github: https://github.com/QuickSpot/walter-simple-housing
Webinar with Soracom.io on 21 November 2023
11/15/2023 at 14:55 • 0 commentsI'm glad to share this project update because I'm invited to give a webinar together with Soracom.io, our global SIM card provider. The webinar will be on 21 November 2023 at 3PM CET. I invite you to register for it via this link: https://www.soracom.io/webinars/iot-devices-walter/
In review by 'The Guy With The Swiss Accent'
11/13/2023 at 11:37 • 0 commentsIt's so cool when you see your hardware being used by others. Andreas Spiess, aka 'The Guy With The Swiss Accent' has received a Walter kit and is looking forward to test it out.
How it's made: Walter
11/09/2023 at 09:16 • 0 commentsWe have filmed the first production run of Walter at the factory in Belgium:
Pre-launch on Crowd Supply
11/08/2023 at 21:41 • 0 commentsWalter is accepted to be crowd-funded on Crowd Supply, the campaign is currently in the pre-launch stage and visible on https://www.crowdsupply.com/dptechnics/walter. It's now key to spread the word to enable us to invest more in extra certifications, tutorials and software libraries.
