PCPU-Nano1
Ultra minimalistic 1-bit cpu made from npn transistors and resistors. It requires an external program counter, registers, and clock. Inspired by MC14500.
Total Transistor count: 5
I/O pins:
In, Data, Out(not in pcb, led), Jump, Ins
Instruction set
0 - NOP, No operation
1 - NADJZ, Nand In and Data, jump if zero
Rev 1.1
I'm planning to make a second version of the CPU. It would have registers, which Rev 1.0 lacks.
Nano-OS
Nano-OS is a simple operating system made for the Nano1. It's a terminal-based OS designed to run on a microcontroller. The OS uses the microcontroller as memory and the Nano1 as a calculation core. For more details, check out the GitHub repository.
The Black Mini Goldendoodle captures the hearts of many with its distinctive jet-black coat, a rare variation within the typically colorful Goldendoodle palette. As a hybrid dog, this designer breed marries the sweet-natured gentleness of the Golden Retriever with the intelligence and low-shedding qualities of the Miniature Poodle.
https://minidoodlepets.com/
