triangle stand arm.SLDPRTThis is the solid part for the arms of the triangle stand.sldprt - 182.75 kB - 02/19/2018 at 18:35 |
triangle stand arm.STLThis is the STL for the arms of the triangle stand.Standard Tesselated Geometry - 9.07 kB - 02/19/2018 at 18:35 |
triangle base.SLDPRTThis is the solid part for the base of the triangle stand.sldprt - 143.63 kB - 02/19/2018 at 01:34 |
triangle base.STLThis is the STL for the base of the triangle stand.Standard Tesselated Geometry - 16.68 kB - 02/19/2018 at 01:34 |
