A simple project based on a inverted pendulum robot
View all 7 components
Using these two tutorial to read raw data :
http://playground.arduino.cc/Main/MPU-6050
http://diyhacking.com/arduino-mpu-6050-imu-sensor-tutorial/
Be careful to use the 3.3V pin to power the board, as recommended in the datasheet and not the 5V.
The test was successful, however to continue we'll have to read a bit about I2C and the way it uses the port INT, SDA and SCL.
The datasheets of the board : Register Map and Specifications, and more info available at I2Cdevlib
Here are some readings from the Serial :
(It even has a temperature sensor)
Here is a capture of acceleration along x-axis :
First bursts are due to manual oscillations of the breadboard along x-axis, the along y-axis for the second perturbation.
The use of a digital filter seems necessary to clean the data.
View all 2 project logs
In this poject which motor you used.
Plesed describe with specification
Ben Peters
gabebentz
EK
lukasz.iwaszkiewicz
Yes, delete it Cancel
You are about to report the project "Self Balancing Robot", please tell us the reason.
