end_effector.STLThe end effector mount.Standard Tesselated Geometry - 433.48 kB - 06/25/2020 at 16:39 |
forearm_mount_motor.STLThis is used to mount the small actuator.Standard Tesselated Geometry - 329.87 kB - 06/25/2020 at 16:38 |
shoulder.STLThis is used to connect the links for the large actuators.Standard Tesselated Geometry - 325.08 kB - 06/25/2020 at 16:37 |
connector_wires.STLThese are the connector links (print 2).Standard Tesselated Geometry - 142.66 kB - 06/25/2020 at 16:37 |
shoulder_mount_motor.STLThis is the mount for joint 3.Standard Tesselated Geometry - 459.55 kB - 06/25/2020 at 16:36 |
base_holder.STLThis holds the actuator for joint 2.Standard Tesselated Geometry - 591.68 kB - 06/25/2020 at 16:36 |
base.STLThe base that mounts to the ground plane, and mounts the actuator for joint 1.Standard Tesselated Geometry - 418.05 kB - 06/25/2020 at 16:36 |
