Ender_Core_XY_Linearrails_Enclosed_Beta.zip***BOM to come soon.***This is a beta of the enclosed 2020 chassis conversion. Since it's in beta, it may still have a few quirks. Power supply mounting is still less than ideal. Would recommend replacing the four frame braces on the bottom with an acrylic panel that the PSU could be taped to using 3M VHB.x-zip-compressed - 22.98 MB - 02/04/2024 at 07:06 |
plain - 959.00 bytes - 11/16/2023 at 10:52 |
Marlin-2.1.2_for_Ender_CoreXY.zipThis is Marlin 2.1.2 configured for the Linear Rail Version. It has some quirks and features so I strongly advice reading the Readme and skipping through the Code yourself. Have fun!x-zip-compressed - 9.42 MB - 02/13/2023 at 15:28 |
Ender_Core_XY_Linearrails.stepVersion that uses linear rails for the XY-Gantry. All parts that are modified from the original version are yellow and dark green.You will need 3x 350mm Mgn12h, M3,M4,M5 bolts, 370mm 2020 and 2 Motherboard standoffs that are used to mount the hotend. If you have questions regarding the conversion i.e. the firmware, don't hesitate to ask! step - 22.85 MB - 01/27/2023 at 19:42 |
plain - 917.00 bytes - 08/30/2022 at 09:23 |
Ender_CXY_V01.zipFull STEP export of the V0.1 assembly.x-zip-compressed - 12.56 MB - 08/30/2022 at 09:17 |
