A sneak peek..
01/06/2024 at 08:10 • 0 commentsHi all,
Tanguy recently added me to this project. I've been working on remixing it significantly, as I was wanting to build an Ender 3 conversion that's capable of being fully enclosed, and ideally should have a bit sturdier of a frame. I'm including a screenshot of what I've come up with so far, and am working on the BOM right now. While I'm excited to share it with you, I should warn that this BOM will be significantly more expensive than the original project!
Edit to add - The frame braces shown below are courtesy of @NoWarrenty over at Printables. I remixed the 165mm brace to create the smaller ones: https://www.printables.com/en/model/264710-printer-frame-stiffening-braces-different-sizes -
Homing Ender CoreXY
02/10/2023 at 17:54 • 0 comments -
Linear rails update
01/30/2023 at 14:08 • 0 commentsThanks to @Barzar who did a really great job working on the v0.2 with linear rails !
Got it !
09/11/2022 at 13:43 • 0 comments -
Buying 3x MGN12H, 310mm linear rail for the V0.2
08/30/2022 at 09:25 • 0 comments -
V0.1 release and V0.2
08/27/2022 at 16:32 • 0 commentsI am gonna release the current version (V0.1) as a single .step file with the full assembly inside.
As you can see in the videos, the V0.1 prints quite well, but it lacks a lot of little things to make it clean (cable management, proper endstop emplacement etc..)
But I am not gonna do that in this version, I want to make it better with linear rail on X/Y, that will be the V0.2 -
Working on all the little things that need to be done to clean this up
08/02/2022 at 15:39 • 0 commentsSKR and rpi box :
Webcam support :
Benchy is here !
07/29/2022 at 09:56 • 0 comments -
It's alive ! (still a lot to do, but it move and extrude)
07/27/2022 at 16:58 • 0 comments -
We need longer wires
07/27/2022 at 16:55 • 0 comments
